Can I link part's material to a library? When I modify the library material I want that parts auto-update
gperri1
gperri1
I created a library called "My library" whit my materials, I created the material named "steel" and assigned it to 50 parts.
Tomorrow I edit in "My library" the "steel" material changing the name to "steel 2". I would like the 50 parts to autoupdate the material to "steel 2" but this doesn't happen because when I assign a material to a part, it is copied in to the document as a local material.
There's a way that I can autoupdate the material of all parts this way?
Thank you
Frederick_Law
If the name is changed, it will not sync.
Different name is a different material.
Same name will sync with this:
gperri1
Other ideas to auto-update a modify in the material?
I need it to auto-update drawings in which I put a text box whit the iProperties "Material"
And other question:
to modify a material in a library I only can create a copy from library to part, modify it, and then recopy in the library.
There is not a way to directly modify the material in the library?
Thank you
Frederick_Law
Might need iLogic or addin to go through and update all old files.
Can't edit Material in library.
Copy to file, edit and save to library.
Don't use "Duplicate".
It make a copy of material, appearance and physical instead of linking.
Creating -1,-2,-3 styles.
Just change the name in file and copy it to library.
gperri1
Thank you for your reply!
I have some experience whit iLogic but I'm not a programmer, any ideas on how to write a code to keep updated all my files?
Frederick_Law
Ask in the Programming forum:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/bd-p/120
I don't have any code to copy Material Library.
It's something I planned to do.
gperri1
I will ask in the programming forum then, thank you for your support!
