Locking Images
Locking Images
rellisEVKA9
Message 1 of 9
Locking Images
rellisEVKA9
There has to be a way to lock an image in place?
I do not want it to move around on me when I am placing text on top of it.
Replies (8)
Message 2 of 9
JDMather
Yes.
Simply add Fixed Constraints or add dimensions relative to Origin or other geometry.
Message 3 of 9
Cadmanto
See if the attached link speaks to your issue and helps you.
https://forums.autodesk.com/t5/inventor-forum/drawing-views-keep-moving/td-p/5703423
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 9
rellisEVKA9
I do not see how I can do that. I am not placing any model files on my drawing sheet to dimension or constrain.
This is more graphical than a part or assembly sheet with a title block.
The project I am working on is more like something in Publisher or Illustrator. Programs that I don't have.
Message 5 of 9
Mark.Lancaster
@rellisEVKA9
I believe @JDMather was indicating to you, to do this in the sketch where you placed/inserted your image.
Mark Lancaster
Message 6 of 9
rellisEVKA9
This is what I am doing....
Customized blank sheet
Manage tab and Insert Object
Create from File and selecting the jpeg from my network and linking it
All I can do is bring it forward/backward or transparency
Message 7 of 9
Cadmanto
Can you post some pics of what you are trying to do?
Sounds like you might be trying to insert an image into your title block.
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 8 of 9
JDMather
Yes, I thought you were referring to a part sketch rather than a drawing.
 I don't have time to experiment right now, and you really haven't provided enough information, but my experiment would include either Sketched Symbols or Border or Titleblock sketch (with placed image) as @Cadmanto suggests.
Message 9 of 9
paulZKN98
A few years later and this question never found it's solution.  I often run into this as well.  Below is an example of a image inserted over a dimensioned view.  I need to drag my dims out of the way, but in doing so it will move the graphic instead.   There is no way to lock the graphic in place.
The only success I have had is to hover over a leader/dimension/text item > Select Other > select your item and manipulate. This prevents an accidental selection/move of the graphic.  I hope this is helpful.
