Export Inventor files to IFC
florian.pigot
Message 1 of 14
florian.pigot
Community Visitor
Community Visitor
I would like export Inventor files .iam to IFC.
How is it possible ?
When I try it, using the built in BIM Exchange > Export Building Components, I have each time a message "operation failed".
I don't understand the reason why.
Regards
Serge COURT
Replies (13)
Message 2 of 14
Mark.Lancaster
@florian.pigot
Welcome to the Autodesk User's Community..
Inventor version and what updates have you applied to Inventor?
Does the operation only fail on this model or others as well?
Mark Lancaster
Message 3 of 14
johnsonshiue
Hi! First thing to check is the compatible Revit Interop is installed. Go to Control Panel -> Programs and Features -> Revit Interop 20xx.
Second, try to export it to .adsk. Does it work? If it does not, it means the BIM Export does not work at all.
Lastly, create a simple assembly and export it to IFC. Does it work?
Many thanks!
Software Test Engineer
Message 4 of 14
I would like to join this discussion.
I can export assembly file in ifc file extension. When I open it in BIM vision, I cannot select components of that assebly. The assembly is one part. Can anyone help me to export it ifc but as a multibody?
Message 5 of 14
EvanGu
Hi, the current .ifc export function combines all assembly components and export them to one single file.
Evan Gu
Inventor/Fusion QA Engineer
Message 6 of 14
Thank you,
Message 7 of 14
The question is, is it possible to sellect the assembly components as a separate bodies?
Message 8 of 14
EvanGu
Not possible, there is only one body in the exported .ifc file.
Evan Gu
Message 9 of 14
Thank you.
Message 10 of 14
Where is the export to IFC function?
I have inventor 2019 and cannot locate on ribbon or anywhere?
Message 11 of 14
johnsonshiue
Hi! Are you using Inventor Pro 2019 or LT 2019? If it is former, you can go to Environment tab -> BIM Content. If it is latter, you will need to download and install Inventor Pro 2019 (trial mode/no license required) so that BIM add-in is installed.
Many thanks!
Message 12 of 14
carstn
Hi
How do I add the Autodesk Revit Interoperability for Inventor to Inventor Pro 2016?
/carstn
Message 13 of 14
johnsonshiue
Hi! For Inventor Pro, it should be installed by default. If you don't have it, simply run Inventor 2016 Setup again. You should be able to add the Add-In.
Many thanks!
Message 14 of 14
ThrainnThorarinsson
I have the same problem and to my knowledge, the option for a multibody IFC export has not been added.
Do you know if there is any workaround, using Revit or Autocad, to achieve a multibody IFC with the iProperties of each part accessible through the IFC?
Thank you.
