Inventor Forum
Inventor: Sweep a rectangular tube at a 90 deg angle
6 REPLIES 6
974 Views, 6 Replies
I am trying to make a swept rectangular tube at a 90 deg angle. I have the dimensions that are needed and the arc, but the bottom face isn't coming out flush (See attached). Any suggestions? or do I over shoot and then cut with an extrusion?
Trevor Jordan
sergio.bertino has edited your subject line (trying to get a 90deg part) and embedded your image for clarity.
Trevor Jordan
6 REPLIES 6
JDMather
JDMather
Your arc is NOT 90°?
Sketch2 is not fully defined?
Is your Profile sketch Perpendicular to your Path?
Attach your *.ipt file here.
Mark.Lancaster
Mark.Lancaster
@Anonymous
The center of the radius is not dimension and floating in space.  Is your sketch fully constrained or does it require "X" number of dimensions.
Mark Lancaster
@Anonymous
Mark Lancaster
The_Angry_Elf
The_Angry_Elf
@Anonymous
From what I can see, as Mark and JD posted, your sketch is not constrained.
I can see that the bottom end of the vertical edge is based off the sketch X0Y0Z0 point, I can only assume the vertical line of the edge is constrained vertically.
What is the distance from this vertical edge to the center of the radius in the X and Y direction? Adding those constraints would constrain the radius and most likely fix your issue.
No offense but why do so many user not constrain their sketches? I see it all the time. It's Sketching 101. But I digress.
@Anonymous
Sergio.Bertino
Autodesk Support
Autodesk Support
Hi @Anonymous,
Could you please attach the files here?
We need to have a look at the part, in order to provide some solutions for you.
Sergio Bertino
MFG Technical Support Specialist
Hi @Anonymous,
Sergio Bertino
here is the part
here is the part
johnsonshiue
johnsonshiue
Hi! I think the only logical reason to explaining the behavior is that the profile plane is not normal to the path at the end point. If it was, the profile projection on the right should pass the center point of the arc.
1) Simply move EOP above Sketch2.
2) Create a normal to path workplane by selecting the end point of the arc and the arc itself.
3) Move EOP to the bottom.
4) Right-click on Sketch2 -> Redefine -> pick the newly created workplane.
Now, the Sweep will work as desired.
Many thanks!
Software Test Engineer
Many thanks!
