Lock drawing view
Lock drawing view
johan.degreef
Advisor Advisor
Message 1 of 19
Lock drawing view
johan.degreef
Can I fix/lock a drawing view's position in an Inventor drawing?
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
Replies (18)
Message 2 of 19
Gabriel_Watson
You could right-click the view and make it Raster?
Message 3 of 19
bradeneuropeArthur
You could lock the views by prevent them to be moved by using the event in the drawing.
Means if you move the view it will warn you and move it back to where it was positioned.
Does that make sense?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 4 of 19
johan.degreef
@Gabriel_Watson That doesn't make my view unmovable...?
Message 5 of 19
johan.degreef
@bradeneuropeArthur I just assign an ilogic rule to the view change event? That doesn't pop up after a simple view move
Message 6 of 19
Gabriel_Watson
Sorry, I did not understand the first question correctly. Raster will not lock the view in terms of its position in the sheet.
Message 7 of 19
sundars
HI @johan.degreef
Unfortunately, there is no easy way to lock a view on the sheet so that it doesnt move positions. You could create some grid lines using a sheet sketch and zone borders and fixing your view on a particular quadrant but you would have to manage the positions manually in case the view is moved.
Another great request for the ideas forum 🙂
-shiva
Shiva Sundaram
Inventor Development
Message 8 of 19
Gabriel_Watson
See if this helps, I don't think it locks views in place but it may prevent them from moving when updates come through. Change your App. Options to Fixed justification, then change the display options of the base view to Fixed as well (use Defer updates to open the drawing so you can choose that before updates come through):
https://www.youtube.com/watch?v=x_9yd45rJYg
Some iLogic that might do what is needed:
https://forums.autodesk.com/t5/inventor-forum/how-to-lock-a-drawing-view-in-place/m-p/8999104/highli...
And as @sundars pointed out, there is an Inventor idea to vote for that:
https://forums.autodesk.com/t5/inventor-ideas/inventor-lock-drawing-view/idi-p/7430490
Message 9 of 19
sundars
@Gabriel_Watson - Nice tip on using Fixed view justification. It is indeed a good way to fix your view center. It should do the job in most cases, the only caveat is that if the model changes, the view bounds would grow (or shrink) along the direction of geometry change but it will keep the center fixed, whereas using center justification grows the view bounds all around. Actually I wonder why we dont keep "fixed" as the default - legay reasons 🙂
Shiva Sundaram
Message 10 of 19
bradeneuropeArthur
You could use the filters to avoid that:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 19
bradeneuropeArthur
And you can use the OnDragEvents
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 19
bradeneuropeArthur
I have created an add in preventing moving views in a drawing.
See the attached movie if this is what you expect.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 19
johan.degreef
https://forums.autodesk.com/t5/inventor-ideas/fix-a-view-s-position-in-a-drawing/idi-p/10946440
Message 14 of 19
bradeneuropeArthur
Does the add in help you in the meantime?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 19
johan.degreef
Video is not playable
Message 16 of 19
bradeneuropeArthur
uploaded again
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 17 of 19
johan.degreef
Yes this is what it should do.
Message 18 of 19
banghn
What event do you use on Inventor Drawing, thanks
Message 19 of 19
bradeneuropeArthur
OnDrag
OnPreselect
and
OnSelect
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
