Limits to a constraint
Message 1 of 11
This is a YouTube video. To learn limit constraint I replicate it. Why is Bucket Handle coming inside the bucket.
Replies (10)
Message 2 of 11
Frank-Oosterwaal
your mate 2 should be a flush constraint.
Change it and the hook will flip to the right position.
Message 3 of 11
Thanks for your help. Could you tell me the reason please.
Message 4 of 11
Frank-Oosterwaal
Hmm let me see if I can explain this correctly:
The picture in the constraint dialog box really says it all.
The mate constraint will make the two selections face to face.
The flush constraint will make the two selections flush.
If you look at the pictures in the dialog box you can see that the two components will flip in orientation by changing it "mate" or "flush".
Better said, it will define the orientation of the two components to each other.
Therefore it will also define the orientation for your angle limit constraint.
In this case your "mate" constraint made the angle limit constraint behave the wrong way around.
By making the "mate" constraint "flush", the hook flipped in orientation to the bucket.
The angle constraint flipped with it and works now the right way around.
I hope I explained it well enough for you to understand...
Message 5 of 11
From Edit Constraint dialog box image if object face is in opposite direction it is MATE, if object face is in same direction it is FLUSH.
It is difficult to identify these things if it is a origin plane alone. Is there any simple method to  identify this?
Message 6 of 11
JDMather
@Anonymous wrote:
It is difficult to identify this if it is origin plane alone.
Workplanes have a front side and a back side.
The front side is a lighter color.
The back side is a darker color.
Light side to light side, then Mate-Flush
Light side to dark side, then Mate
BTW - your "bucket" will hold 0.1 in ^3 (or 1.64 ml) of water.
Message 7 of 11
Thanks for the explanation.
Message 8 of 11
How to determine if you want place Bucket Handle upside then you have to FLUSH.
Is it by trial and error?
Message 9 of 11
JDMather
You can tell by the color of the workplanes.
But that takes too much time (I seldom turn on the visibility of workplanes).
It is faster to just do it by trial and error.
I use several different CAD programs in a single day (often in a single hour), I don't even bother trying to remember or pre-determine the next step as it is so much faster to just do the opposite on these binary decisions if the first guess doesn't give me what I expect.
Something more complicated I will spend a bit more time, but if it is just one way or the other - just do it and observe the behavior.  I suspect that would still be true even if I only used Inventor all day.
Message 10 of 11
SBix26
When choosing planes or faces for the Mate constraint (and angle constraint, too), Inventor places a temporary red arrow on the feature to indicate the normal direction.  Unfortunately, these arrows are typically hidden by other geometry, but you can see them if you zoom way out, because they maintain their size on screen.  These arrows really help to minimize guessing.
Sam B
Inventor Professional 2016 R3 SP2
Vault Basic 2016 SP1
Windows 7 Enterprise 64-bit, SP1
Message 11 of 11
Superman!
