Inventor Forum
Limits of an Inventor part or assembly?
32 REPLIES 32
Message 1 of 33
bill_gilliss
5069 Views, 32 Replies
bill_gilliss
Hello, all -
Visiting from the AutoCAD side of things, I wondered if there was a limit to the size of an Inventor part or to the dimensional extents of an Inventor file?
-Bill
Hello, all -
-Bill
32 REPLIES 32
Message 2 of 33
in reply to: bill_gilliss
AutoCAD is the only unitless CAD system in popular use. Because it is
unitless, there is no maximum distance.
3D Modelers are unit based, and mathematically there is a limit on
individual part sizes. The Inventor 2010 part I have attached is a 5
foot diameter cylinder with a length of 6400 feet. It fails to extrude
somewhere between 6400 and 6500 foot in length. This is a single part file.
Assembly files in Inventor do not have a distance limitation since
individual parts and subassemblies are merely linked, not calculated
within the assembly file.
Do you have a need to create single parts over 6400 feet? BTW, the Mass
of this part in mild steel is: 61661137.021 lbmass (Relative Error =
0.000000%).
Dennis Jeffrey, Autodesk Inventor Certified Expert
Subscribe to the free "The Creative Inventor Magazine now available at:
http://teknigroup.com/CI-Subscribe-Login.asp
0.000000%).
Message 3 of 33
JDMather
JDMather
>Because it is unitless, there is no maximum distance.
Actually the size limit or extreme distance from origin is well known problem in AutoCAD.
Here is info from Rhino - I have seen similar information for virtually all CAD programs I have used.
Rhino, like most CAD products, represents position in double-precision floating-point numbers. That means the x, y, or z coordinate of any point can have a value ranging from as large as ±10E308 to as small as ±10E-308. Most CAD software, including Rhino, uses double-precision floating-point arithmetic.
Because of the limitation of current computer technology, we expect calculations to be accurate to 15 digits of precision in a range from ±10E20 to ±10E-20. This limitation is found in all modern CAD products.
Older CAD products often have additional limitations because they were developed originally to run on computers with less precision. For example, many CAD modelers are designed for performing calculations on geometry that is restricted to be in a box of size 1000x1000x1000 meters centered at the origin. (Geek alert: Another of the popular off-the-shelf modeling kernels requires parameterizations that are within a factor of 10 of being arc-length parameterizations.) Rhino has none of the limitations found in these older products.
Jeff Howard covered this topic here a while back, but now I can't find the thread.
Message 4 of 33
bill_gilliss
bill_gilliss
This is what I was wondering about -- just curious. No 1.2 mile long single parts in my immediate future! Thanks to all.
Message 5 of 33
Here is an AutoCAD file which shows our Solar system in 1:1 scale. If you
zoom close onto the Moon you will see the lunar module over there plus a
memorial plate left by the astronauts.
The file was created years ago to demonstrate AutoCAD zooming capabilities.
BTW, using AutCAD since R12 it is the first time I hear that there is a
"well known problem in AutoCAD" with parts size or extreme distances.
Igor.
Web: www.meqc.com.au
www.boatworks.meqc.com.au
----- Original Message -----
Newsgroups: autodesk.inventor
Sent: Thursday, March 04, 2010 12:04 AM
Subject: Re: Limits of an Inventor part or assembly?
problem in AutoCAD.
Igor.
problem in AutoCAD.
Message 6 of 33
I agree.
Actually, AutoCAD is the only CAD system that can handle angstroms to
parsecs in measurement.
I agree.
Message 7 of 33
JDMather
JDMather
>the first time I hear that there is a "well known problem in AutoCAD" with parts size or extreme distances.
Guess I'll do some research for you and post links to numerous sources and proofs when I get a chance - check back for the urls in a couple of days.
Message 8 of 33
johnsonshiue
johnsonshiue
The maximum size of an Inventor part model (only part) is bounded by a cube of 10000cm X10000cm X 10000cm. When a solid body exceeds the boundary, the modeling commands will behave unpredictably.
For assembly, there is no internal size limit on how big an assembly can be. However, it is restricted by hardware (memory, CPU) and OS (maximum floating number allowed).
Thanks!
johnson.shiue@autodesk.com
Software Test Engineer
Thanks!
Message 9 of 33
JDMather
JDMather
I believe there are a few known tricks to get around the problem. Scaling, inserting....
Here is an interesting read. I'll post more examples as I have time to find.
http://autodesk.blogs.com/between_the_lines/2004/01/more_on_autocad.html
>" Of course by simply moving this object temporarily closer to the origin of 0,0 the offset works perfectly because less digits are used in this calculation and no rounding issues. "
The other examples I will reveal deal with 3D solids editing problems - can't add fillet or can't shell, that sort of thing.
Message 10 of 33
It is funny that you jump into such topic head on but when I asked a real
Inventor question you were nowhere near to see.
Igor.
wrote in message news:6348571@discussion.autodesk.com...
Igor.
Message 11 of 33
Igor,
Have you asked AutoCAD if the feet of the Lunar Lander are flush with the
Moon's surface to 1e-6 cm tolerance? Inventor asks that type of question
all the time.
Roger
"Igor Mironenko" wrote in message
news:6349192@discussion.autodesk.com...
Igor.
Igor,
all the time.
Roger
Igor.
Message 12 of 33
bill_gilliss
bill_gilliss
Sheesh. Didn't mean to stir up a flame war.
Message 13 of 33
Shaan's post does not say anything different that Igor or I had stated.
Yes there is a mathematical limitation that is imposed by the CPU
addressability. However, the scale of creation exceeds that of a solid
modeler as Johnson has stated.
In fact the Invetor part I posted earlier will fail at 6400 ft if
extruded in one direction. See attached
Message 14 of 33
It's not a flame war. Just a gentleman's disagreement... 🙂
Message 15 of 33
JDMather
JDMather
>...when I asked a real Inventor question you were nowhere near to see.
I don't work for Autodesk. Where is your VAR? What about Autodesk Support? There are other people here to answer questions - I am not obligated to respond to every question posted here.
Message 16 of 33
Very true...
"Dennis Jeffrey" wrote in message
news:6349229@discussion.autodesk.com...
Very true...
Message 17 of 33
Jeffrey, he is talking about 64 bit platform. How does it fall into being
"well known problem"?
wrote in message news:6349195@discussion.autodesk.com...
inserting....
find.
inserting....
find.
Message 18 of 33
No, you don't. But the amount of time you spend here on this forum certainly
entitles me to ask "why not?"
wrote in message news:6349323@discussion.autodesk.com...
Message 19 of 33
No Bill, you didn't start any war at all!
I, for one, have a great respect to your work. One of your lisp routines
(M2S.lsp) served me well for many a years.
I am sure this forum will benefit a lot should you decide to go Inventor
way.
Thanks for your support.
Best Regards,
Igor.
wrote in message news:6349218@discussion.autodesk.com...
way.
Best Regards,
Igor.
Message 20 of 33
I guess not. It didn't cross my mind somehow.
Igor.
"Roger Mollon (Autodesk)" wrote in message
news:6349207@discussion.autodesk.com...
Igor,
all the time.
Roger
Igor.
Igor,
all the time.
Roger
