lgs files to inventor 2021
Sahar.IbrahimK54R9
Message 1 of 26
Sahar.IbrahimK54R9
Good morning ,
I want to convert lgs files to inventor 2021 ,is there is a way to do this, and even when i open lgs with AutoCAD ,and want after to open the cad file with inventor, it does not showing anything ,Thank you al  for your help.
Accepted solutions (3)
Replies (25)
Message 2 of 26
Frederick_Law
Most IGS come with surface and lines.  No solid.
Check your import options.
Message 3 of 26
Sahar.IbrahimK54R9
Thank you very much for your help, but it doesn't want me to open the file, Thank youSaharIbrahimK54R9_0-1678456217739.pngSaharIbrahimK54R9_0-1678456217739.png
Message 4 of 26
Frederick_Law
Did you use Open or Import CAD Files?
Message 5 of 26
Sahar.IbrahimK54R9
I tried both, but the problem is the option button is not active when i tried to import, I don't know why, thank you very much!
Message 6 of 26
Frederick_Law
When you import, change File Type to IGES.
Select the file you want to open.
You should be about to click Option.
Message 7 of 26
kacper.suchomski
Can you attach your file?
Kacper Suchomski
Message 8 of 26
Sahar.IbrahimK54R9
I attached the file ,Thank you very much.
Message 9 of 26
Sahar.IbrahimK54R9
the igs doesn't wanted to be attached, he is telling me it is not supported, Thank you
Message 10 of 26
Sahar.IbrahimK54R9
I tried but again ,it is not working, for x reason it doesn't want to give me the option button, Thank you very much for your help
Message 11 of 26
kacper.suchomski
The dwg file doesn't contain anything either. It only has a few placeholder points when referring to external objects.
Kacper Suchomski
Message 12 of 26
Frederick_Law
zip the igs file before attach
Message 13 of 26
Sahar.IbrahimK54R9
Thank you
Message 14 of 26
Sahar.IbrahimK54R9
Message 15 of 26
Frederick_Law
You attached a CWPRJ file.
Not IGS file.
Message 16 of 26
Sahar.IbrahimK54R9
because of the size of file is very big to be attached, Thank you
Message 17 of 26
Frederick_Law
What size is the zipped IGS file?
You can put it in Google Drive and share it.
What supposed to be in the IGS?
Can you ask for STEP or Parasolid file?
What CAD created the IGS?
Message 18 of 26
Sahar.IbrahimK54R9
I will put it on google drive, Thank you very much
Message 19 of 26
Frederick_Law
You know how to share just a file and not everything in your Google Drive?
I don't want you to share everything by mistake.
Message 20 of 26
Sahar.IbrahimK54R9
Thank you very much ,but i know how to share i file i want only 😀 ,Thank you again!
