Levels of Detail (LOD)... Is it just me, or does anyone else....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is it just me, or does anyone else love Levels of Detail (LOD) views.... until you have to use them?
What I mean by this is, Rep views are great, they help you prepare for your drawings and get stuff out of the way to see what is going on.
The "problem" I run into with LOD views is that while they are great for setting things up, they are horrible for anything that happens "AFTER" they have been created!
Here's the example:
I currently have a project that is a complicated control panel, flexible hose, hard tubing, electrical harnesses, internal and external parts, doors that open and close, etc. So I have created a few dozen LOD's. the project has been released, but is now up for a revision change. Of course, like many revisions, parts have been replaced, removed, added. this is easy enough, but it completely changes each LOD for anything added! which as you most likely already know, requires you to go into each LOD and suppress the added or changed parts.
Unless I am missing something, the way the LOD's should work is like this:
Once a LOD is created, Inventor should be smart enough to know they exist, that anytime a part is added/replaced a window should open that contains a checkbox layout showing each LOD and asking the user to choose if the new/replaced part is to be included in the list of LOD's, this way a user, in this case (me), won't have to add one part today, then spend 5-6 hours editing each LOD and fixing drawings views, only to have to repeat that work the following day when something else is added.
I like the LOD's, but they only seem to work if no changes are made to them... (again, unless I'm missing something)!!
