Design Assistant - how to change quantity, material, and description properties
jeremy_krause
Observer Observer
jeremy_krause
Observer
Observer
We are trying to find a way to quickly change the quantity and description of many drawings without going into each file and changing them. We thought there might be a way to do this within design assistant but are unable to find a way. We also have assemblies that contain most of these parts. These assemblies have parts lists within them that detail the quantity and description of the parts it contains. Is there a way to pull from the parts list within the assembly drawing file into each individual part drawing? Also is there a way to quickly change the material description in the drawing files without opening each individual file and changing it from the file itself? any help to these questions would be greatly appreciated.
johnsonshiue
Hi! Some of the properties you are changing are BOM properties, which Design Assistant may not have access to.. I think you can open the assembly (instead of individual parts) and make such change on the BOM table. Would it work for you?
Many thanks!
Software Test Engineer
jeremy_krause
Observer
Observer
Thank you so very much. Extremely helpful.
