Dear All,
I am working on a process for crankshaft manufacturing. One operation is called Deep Rolling, where we use high force in the undercuts of each main and pin bearing. After this operation the crankshaft will be 0,3 - 0,4 mm longer.
I am using "derive" for every operation (OP10 - 20 - 30....), so every OP has its own 3D model.
Is there any option to "create" this kind of modification on the crankshaft? (every bearing width will be different and the whole crankshaft will be longer)
Thank you for your help!
Solved by johnsonshiue. Go to Solution.
Hello @Anonymous
iParts or iAssembly could work to create different sizes of the model.
iLogic is also another way. This is more advanced, so depending on your knowledge of inventor.
Hope this helps.
Thomas.
When creating a part , you can set a parameter using the F(x) menu.
You can set this parameter (on the specific part that is lengthening) to "mutli value" and enter all the desired lengths .
Then you can select the disered length and the part will adapt accordingly . You can then create an assembly and constrain everything.
Hope I made myself clear,
There are more complex ways to make it work, but I don't have the time atm.
Best regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"Hello All,
What do you think about this solution:
Create e.x.: operation 30, where I mill the width of the bearings. I make an IPart out of Op30, and then a Derive the model, and create the next Opeartion. Can I change the width now in the new derived model?
I made an example, and I can see all of the parameters in the "Derived Part" Window, but I can not change the parameters with the F(x) command.
is there a possibility to "open" the parameters in the new derived model?
Hello @Anonymous
Could you attach your model please?
Thomas.
I created the model "alap", I made it to an IPart, then a used it to create with "derive" the next part: ALAP_DERIVE,
Now I want to change the parameter "VAS" in the ALAP_DERIVE Model.
I've tried a bit and i can't find a solution. "Derive" may not be the best way to accomplish what you are looking for. If I understand correctly, your goal is to have one model.iam for each operation ? (Ex : If 30 operations, 30 models)
If this post helped out in any way to solve your question, please drop a "Like"Yes,
I can start with a Raw Part model which is created by a Designer
first Operation is to mill the both ends of the crankshaft -> I derive the Raw Part and make the Milling
next is a Turning Machine - derive Op10 - remove material
next Op20 .......
In Op60 (deep Rolling) -> derive OP50 -> and change the whole lenght of the crankshaft which was created in OP10
Derive is a good option, because If I change something f.e.: in Op20, than every next operation is automatically updted and also the tons of 2d Drawings.
I've looked a bit on previous threads. This might help :
https://forums.autodesk.com/t5/inventor-forum/derived-part-with-editable-parameters/td-p/574609
If this post helped out in any way to solve your question, please drop a "Like"Have you tried using Direct Edit on the derived model to stretch out each bearing face? That may give you what you need if each it is only the bearing faces that need modifying. The overall length of the crankshaft would increase by the sum of the individual bearing face stretches.
Mike.
It is a possibiliy, but f.e.: I have at the very end of the crankshaft I have a center holes, so it is not true that only the outher surface of crankshaft will be "longer" it has also an effect of the center holes. I would have to change not only the side surfaces of the bearings but also dimension of undercuts, axial position of center holes.
It is a little bit as douth kneading 🙂
Hi! I believe you are trying to drive multiple components and some components have dependency, right? When you need to drive components, iPart/iAssembly is not the choice. It is because they were designed to be self-contained components clearly defined by their author tables.
I believe the best option at the moment is iLogic. You can drive any parameter from any level within an assembly. Once you have created one variation. You can use iLogic Design Copy to spawn it. Then you can work on next variation.
Many thanks!
