Inventor Forum
leaf springs
15 REPLIES 15
Message 1 of 16
1848 Views, 15 Replies
leaf springs
Hi folks,
Is there a way to simulate the flexion of a leaf spring under load?
Thanks for your assistance
Randy
15 REPLIES 15
Message 2 of 16
Oh don't I wish. The only thing I have done is model the pack both ways...free height and loaded. "rfowler24" wrote in message news:5380259.1084995306165.JavaMail.jive@jiveforum2.autodesk.com... > Hi folks, > Is there a way to simulate the flexion of a leaf spring under load? > > Thanks for your assistance > > Randy
Message 3 of 16
Look at the Scissor.iam, in the Sample files that came with Inventor. Mike "rfowler24" wrote in message news:5380259.1084995306165.JavaMail.jive@jiveforum2.autodesk.com... > Hi folks, > Is there a way to simulate the flexion of a leaf spring under load? > > Thanks for your assistance > > Randy
Message 4 of 16
Here is a sample Gabriel "rfowler24" wrote in message news:5380259.1084995306165.JavaMail.jive@jiveforum2.autodesk.com... > Hi folks, > Is there a way to simulate the flexion of a leaf spring under load? > > Thanks for your assistance > > Randy
Message 5 of 16
Sort of. You can use adaptivity to deform the spring relative to the axle position. It's a real memory hog but could be used to create an avi. I have an old example of an adaptive coil spring if you're interested. Pat
Message 6 of 16
Nice one!! "Gabriel" wrote in message news:40abc3dc_1@newsprd01... > Here is a sample > > Gabriel > > > "rfowler24" wrote in message > news:5380259.1084995306165.JavaMail.jive@jiveforum2.autodesk.com... > > Hi folks, > > Is there a way to simulate the flexion of a leaf spring under load? > > > > Thanks for your assistance > > > > Randy > > >
Message 7 of 16
That's pretty cool. Here is another challenge for you. What I'm actually trying to do is demonstrate the action of a reed type switch on a test fixture. In other words, one end is anchored, the free end flexes uniformly when contacted by a pin, and the overall length remains constant. Maybe too much to ask??? The scissors model is promising but I won't be able to drive it with an angle constraint. I will have to try to make it adapt with a transitional constraint?
Thanks for your responses and help.
Randy
Message 8 of 16
I guess this is what u want (see attachment). It's not a clean assy , I just updated the previous one. Gabriel "rfowler24" wrote in message news:6224597.1085051218459.JavaMail.jive@jiveforum2.autodesk.com... > That's pretty cool. Here is another challenge for you. What I'm actually trying to do is demonstrate the action of a reed type switch on a test fixture. In other words, one end is anchored, the free end flexes uniformly when contacted by a pin, and the overall length remains constant. Maybe too much to ask??? The scissors model is promising but I won't be able to drive it with an angle constraint. I will have to try to make it adapt with a transitional constraint? > > Thanks for your responses and help. > > Randy
Message 9 of 16
Thanks for your help Gabriel, that is exactly what I need. That is pretty cool.
Randy
Message 10 of 16
HenrikGraversen
I would love to see your adaptive coil spring.
Henrik Graversen
Message 11 of 16
i like how you did this....however...when you bend it your changing the part. in an ipt. what command do you use to make the part itself flexible?
attached is a part that is definatly sheet metal and needs spring action, any help?
Message 12 of 16
im using version 10 by the way
Message 13 of 16
gabrielgavrila
Hi Randy,
Can you please post the leaf spring sample if you still have it?
Gabriel
Message 14 of 16
JDMather
in reply to: gabrielgavrila
This thread is 10-yrs old, I don't think these users are around any more.
Can you attach the assembly of what you have completed so far?
There are others ways to accomplish this in later releases.
What release of Inventor are you using?
Message 15 of 16
blair
in reply to: JDMather
The last post Randy made was in March of 2008
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 16 of 16
gabrielgavrila
I'm using inventor Professional 2015,  I'm trying to stretch a part in an assembly when I drag it, like an elastic band, section can stay same.
I posted that sample with something similar when I replyed to Randy 10 years ago, but I forgot how I did it (getting old).
I appreciate your help.
Gabriel
