Last Active State for Design Reviews not functioning, Always reverting to Primary
jason.kellyNMSQ4
jason.kellyNMSQ4
When you save the assembly with a custom view rep, it should open with that view rep active. It opens with the Primary state active (see video). This is in 2024.3.4, previously working in 2023 Inventor this worked successfully.
robbeRtek
there are also some open options in the application options.
it could be that they are used instead...
Thanks to accept as solution, if it help you to solve the issue.
regards.
Robbe
johnsonshiue
Hi! I believe there is a regression in 2025. It used to work fine indeed. Please take a look at the following thread. Feel free to contact Autodesk Product Support to escalate a fix.
https://forums.autodesk.com/t5/inventor-forum/application-options-file-open-setting-being-overridden...https://forums.autodesk.com/t5/inventor-forum/application-options-file-open-setting-being-overridden...
Many thanks!
Software Test Engineer
