Hello All
I have the below scenario.
I have a curved solid body, I select the face I want as the true shape, by defining it as the A-Side.
With the K Factor set to zero, I reasoned that the flat pattern would be the true shape of the selected face.
Because the shape is a conic, in theory the top and bottom arc lengths should remain constant from the curved face to the flattened true shape.
However, in practise, I have found that this works for one of the faces but not the other??
I have 2 parts. Both contain the same solid body. On one I defined the A-Side to the inside face, the other the outer face. Both parts have K factor set to 0.
However, the flattened result remains the same?!
Therefore, on one of the parts the flattened shape is calculating correctly with the k factor referencing the A-Side. The other seems to be ignoring it.
However, on the part that isn't behaving as I would expect, if I change the k factor from 0 to 1, it gives me the true shape of the selected A-Side.
What is going on here?
It would seem that the A-Side is ignored entirely when flattening the solid. Which is surely incorrect!
Screen recording attached for clarity, and ipt files for testing.
