Inventor 2026 problem with Color Schemes
olof_andersson
Message 1 of 10
olof_andersson
After installing Inventor 2026 I can no longer change the color of the background to other then the default ones. When I made a personal color scheme and there changed the background color it just default to green if I use gradient and to white if I use 1 color. Do someone else have the same problem or is it just me?
Replies (9)
Message 2 of 10
johnsonshiue
Hi Olof,
Did you import the options or you set them manually? Try exporting the options as an xml file and send it to me directly (johnson.shiue@autodesk.com). I would like to understand the behavior better.
Many thanks!
Software Test Engineer
Message 3 of 10
jonathan.victor
Hi I've installed 2026 and I'm also having trouble with color schemes: When I create a custom color scheme, the color settings randomly changes itself just after applying them. See below, the first picture is the option I choose, the second one is just after applying and opening again. I also  tried rebooting Inventor and PC, the problem occurs every time I change the color scheme settings, and every time, it sets random colors on sketch entities.
I can attach multiple examples for this behavior/bug. Does autodesk has a solution yet?
Message 4 of 10
SharkDesign
I've had issues in the past where I've changed the background and it didn't do anything. I had to switch to a difference scheme and switch back for it to work. I thought they'd fixed that now though.
  Inventor Certified Professional
Message 5 of 10
maulik_patel
Hi Olof,
Thank you for reporting this issue.
This is a known problem, tracked as INVGEN-84351, and our developers are currently investigating it. We hope to have a fix available soon.
It appears that the issue is related to the Windows 'Region' setting. If the region is set to 'English (US)', the problem does not seem to occur. Could you please check your region settings and let me know if you observe any different behavior?
Best regards,
Maulik
Maulik R Patel (maulikr.patel@autodesk.com)
SQA Engineer, Inventor
Autodesk, Inc.
Message 6 of 10
olof_andersson
I changed the region to English (United States) but still have the same problem.
As you can se in the picture the background defaults to blue/green even thou that is not the one I selected.
Message 7 of 10
olof_andersson
just for your information, update 2026.0.1 did not resolve this issue.
Message 8 of 10
johnsonshiue
Hi! I just check the status of INVGEN-84351. Indeed, it has not been resolved. At the moment, it is not targeting any update. Please feel free to contact Autodesk Product Support to escalate the issue.
Many thanks!
Message 9 of 10
jonathan.victor
Hi Johnson, any thoughts on the color schemes issue I reported earlier?
Message 10 of 10
olof_andersson
Hi everyone,
I just got a phone call from Autodesk after I escalated the case where they informed me that this issue will be resolved in the next update.
