K-Factor Not changing Inside radius
henryjoseph9804
henryjoseph9804
Hi All,
I currently have a situation where I need to draw up some stuff from an old drawing. The material thickness for one of the plates is 5mm but with an internal radius of 3mm. I tried adjusting the K-Factor to give me an internal radius of 3mm but with no luck.
Can anyone perhaps provide me with some guidance?
Lars_Greft
Hello, if you open "Sheet Metal Defaults", then click on the pencil icon and go to the tab "Bend", there you can change the Bend Radius.
henryjoseph9804
Thank you so much!
