Inventor Forum
IV2013 SP2 - Ribbon glitch with Manage tab
7 REPLIES 7
Message 1 of 8
RobSinglehurst
656 Views, 7 Replies
I get the above now and again when going into the manage tab. Closing and restarting Inventor will sort it but it's a bit tiresome.
Anyone else seen this?
Cheers,
--Rob
Inventor 2024.2
7 REPLIES 7
Message 2 of 8
-niels-
in reply to: RobSinglehurst
I've seen that too when we were on 2013, not sure if it's still happening but don't think so...
Anyway, i believe that by collapsing the ribbon also fixed it.
(clicking either the grey arrow or doubleclicking on the tab and cycling through all the different sizes.)
Not great, but better than having to restart inventor.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 3 of 8
in reply to: -niels-
I've seen it as well. I usually have to reboot.
Message 4 of 8
RobSinglehurst
I'll give that a go next time it happens.
Cheers,
--Rob
Inventor 2024.2
Message 5 of 8
Rob,
That is usually graphics driver related.
We do not test Geforce cards but here is the link to the NVIDIA's drivers:
http://www.nvidia.com/Download/index.aspx?lang=en-us
Have a great weekend.
Bob Holland
Autodesk Product Support
Message 6 of 8
MegaJerk
Yep! That's exactly how I solve that problem. Interestingly enough this only seems to happen with the Manager portion of the ribbon. Is it the same for you (and everyone else)?
If so, I wonder why it's only that particular tab.
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
Message 7 of 8
Also please make sure that your
Control Panel\All Control Panel Items\Display
is set to default.
We have found that scaling will some time cause this type of an issue.
Thank you.
Bob Holland
Message 8 of 8
Hi Bob,
Mine are set to default - the collapse ribbon is a pretty easy workaround anyway.
Cheers,
--Rob
Inventor 2024.2
