Issue with new 2021.0.1 udate, parameters
bsidesign
Message 1 of 9
bsidesign
I was wondering if anyone else has noticed that after installing the latest update for Inventor 2021 that while in parameters if you try to check the export or key box it will lag forever before checking the box?
Replies (8)
Message 2 of 9
johnsonshiue
Hi! The behavior does not sound right. Please uninstall 2021.0.1 to restore the correct behavior. I will work with the project team to understand it better.
Many thanks!
Software Test Engineer
Message 3 of 9
dcarr
I am having the same issue with this update.  How do you uninstall the update?  I tried reinstalling inventor and it automatically installed the update.  Same issue.
Message 4 of 9
bsidesign
I also had to completely re-install Inventor to get rid of the update. I
had to change my download settings on Autodesk.com not to include updates
in-order to fix this.
Message 5 of 9
johnsonshiue
Hi! you don't have to uninstall and reinstall Inventor. You can uninstall just the update. Go to Control Panel -> Programs and Features -> Show All Updates. You will see an entry for 2021.0.1.
Another thing to check is to go to "Turn on or off Windows Features" and make sure .Net 4.8 is enabled.
Many thanks!
Message 6 of 9
bsidesign
Good to know, thank you.
Message 7 of 9
tobias
I like to add some more issues so far:
1. In BOM, RMB on the column headings, the menu dissapears when releasing RMB
2. On the hole function the both direction button is missing
3. Cannot name parameters in the parameter window. I think this is already mention somewhere else on the forum. You can name the parameter, close the window and re-open, then the name will appear.
We uninstalled the update also.
Kind Regards,
Tobias
Tobias
The Netherlands
Inventor Pro 2026, Vault Pro 2026, AutoCad Electrical 2026.
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Message 8 of 9
johnsonshiue
Hi Tobias,
I am sorry I am not aware of these issues. Do you mind sharing a bit more detail? Or start new threads for each?
Many thanks!
Message 9 of 9
tobias
Done!
Tobias
The Netherlands
