Continuing Hose Runs
sjordash
sjordash
I am running Flexible hoses in Inventor starting at a fitting then picking some points. If I make an error in the picked point, press esc how do I continue the same run from the good point? All I seem to be able to do is start a New Route from the point the hose stopped. This ends up having a number of routes within the run.
johnsonshiue
Hi! I believe you can delete a node and insert a node. It should work. You don't need to create new route if not necessary. Please share an example here and forum experts can help take a look.
Many thanks!
Software Test Engineer
sjordash
Thanks but found that although the Route icon on the toolbar is greyed out if you click on the end of the hose, right click, there is a Route option so you can continue the route!
