I'm looking for a shortcut or command alias for trim-function in the 3D-modeling.
The trim-function, which I can find in the "Tools" -> "Options" -> "Keyboard-tab", is categorized for "Sketch", so I cannot assign a command alias for the trim-function in the 3D-modeling.
Maybe the trim function in the Sketch mode and the trim for surface model in 3D modeling are not even same thing.
Is there a way to assign command alias for trim-function in the 3D-modeling -> Surface?.
Thank you in advance!
I'm looking for more comfortable way to edit surface models, but I have to say, Inventor is not the best supportive platform to work with surface models.. It doesn't even let trimming / splitting multiple surfaces...
Solved by rdyson. Go to Solution.
