Is it possible to replace a filepath in an assembly?
BrennanJWilkie
Message 1 of 8
BrennanJWilkie
There is a part in my library that I use which has a 3" hex standoff as part of the assembly. To match up with the rest of the library at my company, I have renamed the file to something along the lines of 1111-2222. Every time I open up the assembly file, it asks me to specify the file path to the hex standoff (which I know can be fixed by using the correct project file with a proper library, but I'll get around to that another time).
So my question is: is there a way to make it so that when I open the assembly file, the file that is being requested in 1111-2222 and not "3 in HEX standoff"? This will make it easier for others to find the requested file until I can get around to fixing the project file.Capture.PNGCapture.PNG
Replies (7)
Message 2 of 8
todd_cannon
Most likely what is going on is that when you copied the 3 in hex standoff, you didn't rename the part number. Check to see what the part number for the 1111-2222 part is. I bet it still says 3 in hex standoff...
Hope it helps you,
Todd
Message 3 of 8
BrennanJWilkie
You mean in the Part Browser on the side when in the assembly? Because it is renamed to 1111-2222 there, but it would automatically do that since I choose the 1111-2222 file when it prompts me to resolve the link for "3 in HEX standoff". I want it to not say "3 in HEX standoff" when it is prompting me to resolve the path, but instead say 1111-2222.
Message 4 of 8
todd_cannon
No, I'm not talking about the browser node name. Right click on the 1111-2222 part file and select iproperties, go to the project tab and see what it says for part number. The part number is initially created when a new part is saved. At that time, Inventor uses the filename and creates the part number. After copying a file, as you did, renaming the filename doesn't change the part number to the new filename. You should probably rename the part number to agree with the new filename (1111-2222).
Cheers,
Todd
Message 5 of 8
mdavis22569
Yes ...you answered it yourself:
Why not just fix it from the start. There are reason's for IPJ's and file workspace.  Spending more time trying to find a work around than just resolving it the right way.
If you maybe add the path to the file workspace ... you won't have to keep doing this.
Mike Davis
Message 6 of 8
BrennanJWilkie
I'll accept this as an answer for the sake of having it marked off, but if anyone else knows if it's possible to do what I was asking initially, I'd appreciate that too. Thanks @mdavis22569@todd_cannon
Message 7 of 8
mdavis22569
How did you rename it to 1111-2222
You can do a replace component it and save it ....repathing it.
The biggest issue is that the file is outside of the workspace most likely....
Mike Davis
Message 8 of 8
BrennanJWilkie
It was renamed automatically when I manually choose the filepath when I open the Assembly file. The file can't be found initially, because the first place that I had the file has since been deleted.
