Is it possible to have the export object set by befault for new created boddy in Inventor 2022?
hans-eric.vendelson
hans-eric.vendelson
I would like to have the option Export Object set by default in new created bodies (for example when a mirror is done)
johnsonshiue
Hi! I guess it will need an iLogic rule. I don't think there is an out-of-box solution.
Many thanks!
Software Test Engineer
Gabriel_Watson
You can probably export all objects in one shot through Manage (tab) > Author (panel) > Export Objects. I have not yet been able to find any iLogic snippets for that automatically though.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014...
johnsonshiue
Hi! Please bear with me. I am an novice iLogic user. Here is a simple iLogic rule to set all solid bodies exported.
Just create this rule and run it as you wish or trigger it on open.
Dim oDoc As PartDocument = ThisDoc.Document
Dim oCompDef As ComponentDefinition = oDoc.ComponentDefinition
Dim oBody As SurfaceBody
Dim i As Integer
i = 1
For Each SurfaceBody In oCompDef.SurfaceBodies
oBody = oCompDef.SurfaceBodies.Item(i)
If oBody.Exported = False
oBody.Exported = True
i=i+1
Next
Many thanks!
