Hi guys,
As i am still learing to use inventor, i am coming on this forum to save a bit of hours or tests.
I am trying to create a spheric container with a irregular pattern of different triangle as show in the example attached.
What would be the best way to creat this part? i was thinking of creating each triangle in a different .ipt and after assemble them all toghter. But this will take ages and a lot of ipt.
anyone has a better solution?
I think I would do that part in AutoCAD in the surface environment.
You might post this question over there.
Basically you can convert a sphere (or part of one, or any shape) to a mesh and using a technique of subdivision modeling pull vertices in or out (I assume this is art and not exact distances you need).
There might be some examples of the technique here http://au.autodesk.com
