Message 1 of 14
- Mute
- Permalink
- Report
I'm experiencing an issue where the iproperties for a part component do not match the property value of the part itself. I have a custom iproperty with the equation "=<Material>". I've figured out a better way to what i intended, but i still want to bring up the issue.
Issue:
iProperty correct when checking with part open
iProperty incorrect when checking from assembly open
I checked the value in the part and it is correct, but when you check the same property in an assembly it is incorrect. I have no idea what would be the cause of this. Rebuild all does nothing to change this behavior.
Anyone have any thoughts?
