ipj files double click not functioning, new with Release: 2021.1.2
D0UGLAS
Message 1 of 33
D0UGLAS
Double clicking on a IPJ file is not opening that IPJ files and setting it to active in Inventor.
Replies (32)
Message 2 of 33
SBix26
I just installed the 2021.2 update, and just tried opening Inventor by double clicking on a .ipj file.  Inventor 2021 started, but did not display the home screen and did not activate the project that I double clicked on.  Is that what you're seeing, or something different?
Sam B
Inventor Pro 2021.2 | Windows 10 Home 2004
LinkedIn
Message 3 of 33
D0UGLAS
Hi Sam,
Yes that's it. I have always opened my project folders this way as it was such a easy thing to do, now I have to create a link in inventor to access my project folders. I hope this gets put back to how it was soon.
Maybe there is a default flag that has been switched back during the update?
As the update was today maybe I am on 2021.2 also.
Message 4 of 33
ChrisMitchell01
I also see the same issue. It's currently under Dev/QA investigation (against issue INVGEN-47832).
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 5 of 33
D0UGLAS
Hello Chris,
(NVGEN-47832)
This change is having a major impact upon my workflow, as would rollingback versions?
I can be working with or creating 7 or 8 different ipj files a day.
How long will it take to find a fix?
Kind regards
Douglas
Message 6 of 33
johnsonshiue
Hi! The project team is working on a fix. It will be available on the coming update to 2021.2. I am sorry for the regression.
Many thanks!
Software Test Engineer
Message 7 of 33
robertast
It happens from time to time, I just don’t really understand who is to blame. Sometimes this has happened in the past, due to a Windows update, but has been corrected with another update. This time the Windows update coincided with the Inventor update and it is not clear what caused this error.
Message 8 of 33
dwweekly
Yea,
I create a seperate ipj file for each job, and double click them in the explorer.
NOTHING, it opens my previous "active"(checked) project file.
I have to open Inventor, go to projects, and then choose a project(checked), THEN open a file
Message 9 of 33
robertast
@dwweekly
Everyone knows about it. Does not yet know where the error is, either in the inventory or in Windows Update.
Message 10 of 33
D0UGLAS
A sort of horrible fix....
So I can right click on the chosen project ipj file,
then select edit,
up pops the project file editor,
I can then tick the new short cut, close the editor
then double click the ipj file and inventor will open in the chosen correct project..
I much prefer the old method!
Message 11 of 33
robertast
@D0UGLAS
Thanks for the method, this is at least a temporary solution until the bug is fixed
Message 12 of 33
johnsonshiue
Hi! Another workaround is to uninstall 2021.2 update until a fix becomes available.
Many thanks!
Message 13 of 33
pavlosvvv
Unfortunately, even if you uninstall the 2012.2 update the problem won't fix.
I had to uninstall inventor and make a new installation...
Message 14 of 33
dwweekly
I guess Autodesk just has to hurry up and fix their fix!😉
Message 15 of 33
ChrisMitchell01
An Inventor fix for this is currently underway with a potential target release of 2021.2.1 (early/mid Dec). It doesn't seem to be related to windows updates from what I've seen.
-Chris
Chris Mitchell
Autodesk, Inc.
Message 16 of 33
google translate JP to ENG
I want you to fix it soon
Message 17 of 33
jhkwonCBNCM
I'm in the same situation.
window browser and ipj double click .. Nothing happened
inventor version 2021.2
Message 18 of 33
pockybum522
This fixed it for me. I have the version mentioned in this thread, and I know the below thread calls out a 2020 version, but it still worked. Specifically, make sure to remove the space.
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Doubl...
Message 19 of 33
D0UGLAS
This did not work for me, I was not very keen on changing the registry either.
Message 20 of 33
pockybum522
It looks like when Inventor launches it very helpfully changes the entry back to have a space (the broken mode)
