IPJ file standard setting
aniket_arulkar
aniket_arulkar
Is there any standard .ipj setting guideline available ? So that whenever creating .ipj file first time that will helpful for him.
johnsonshiue
Hi Aniket,
Try this and see if it helps. Go to Tools -> App Options -> File -> Default Project folder. Go to the folder and find Default.ipj. This project should be the seed project when a new project is created. Edit the ipj file (xml) in a text editor. Make the necessary change accordingly. I believe the new project should be based from the options set in the Default.ipj.
Many thanks!
Software Test Engineer
