Inventor Forum
Lights not appearing in render
2 REPLIES 2
lu3a
206 Views, 2 Replies
i'm new to rendering in inventor; i have a simple question, the lights setting that i've put are showing before rendering, but not as a final result; can someone tell me why? I tried out anything but i won't work.
I put two pics so you can understand.
Thanks for help in advantage.
Tags (2)
Labels (1)
2 REPLIES 2
CGBenner
in reply to: lu3a
@lu3a Welcome to the Inventor forum!
What version of Inventor are you using?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
johnsonshiue
in reply to: lu3a
Hi! This could be related to unmigrated appearance style. Try this real quick. Compare the look between Shaded View and Realistic View in Visual Style. Do they look very different? If yes, this means the appearance styles were created in 2018 or earlier. You may need to open each part and edit the appearance style -> change the description -> change it back -> Ok.
Many thanks!
Software Test Engineer
Technology Administrators
