Inventor Forum
iPart variable pattern
5 REPLIES 5
Daan_M
578 Views, 5 Replies
Hi Forum, bit of a newbie question
I'm currently drawing a flange to create a iPart factory. Theres holes in the flange for assembly, but for every flangesize, this pattern is different, see the picture below.Flange2.jpg
Ofcourse i like to keep my drawing as simple and clean as possible. But because of these different angles for every size i'm not sure what the best method is. I managed to draw these flanges but the drawing and Excel get a ton of extra parameters an it's a bit messy.
What method would you apply to create this?
5 REPLIES 5
Mark.Lancaster
in reply to: Daan_M
@Daan_M
Are you actually making a drawing or modeling it?
If you're going to make an iPart of this, you would have to create different patterns and then enable/disable them (the patterns) for your members..  In my opinion reviewing the info you provided, there's not a lot of common stuff in the circular pattern that makes this an iPart candidate.   But that's my 2 cents..
Mark Lancaster
Daan_M
in reply to: Mark.Lancaster
I'm looking to make a iPart yeah. I had the same view, there's not much in common within these patterns, but they're still all circular with holes. I thought maybe i've overlooked a easy tool to create this, without making individual patterns with dimensions for each single one.
In the end it is no problem, i was simply looking for a optimalization if there was one, thanks.
daneYNCUX
Is there no way to suppress pattern occurrences within an IPart member?
johnsonshiue
in reply to: daneYNCUX
Hi! Unfortunately, it is not supported in iPart/iAssembly/Model States.
Many thanks!
Software Test Engineer
daneYNCUX
in reply to: Daan_M
oops, wrong string, my bad.
