- Mute
- Permalink
- Report
IV 2016, Windows 7 64 bit
I created an ipart "RUB RAIL, 3in.ipt" a few years ago. (I've attached a screen shot of the table)
This morning I added a variable for calcualting surface area, and generated the files. Instead of generating the children by the member name, it generated by all the variables. I deleted the new surface area parameter, and regenerated. Same style of naming for the children. I closed everything out and used a shadow copy to restore a versin of my ipart from a month or two ago. opened it up, generated files, and the naming of the children files was still the same. (See attached capture.png)
I updated to "Autodesk Inventor 2016 R2" update this morning.
I created a test part with a few basic variables. It named the children correctly. I added an appearance variable to that table, and generating te files still worked correctly.
I really want the ipart to name the part files it creates by the member name. Any ideas of what's happening or how to fix it..?
Thank you!
