Video Card HELP!
Video Card HELP!
Rblaque
Message 1 of 8
Video Card HELP!
Rblaque
Sorry, i did search this but came up with some ambiguous and out of date information
Im building a second desktop machine for one of our engineers and I am by no means a hardware guru. We will be running Product Design Suite Ultimate 2016. My roadblock seems to be what video card to use. Ive heard the Quadro line isnt necassarily the best route even though it is recommended by Autodesk.
We run some pretty robust 1000+ part assemblies ......ive added a screenshot of a typical assembly
Can someone give me some experienced input on a card?? Make it easy.........just give me a no brainer Model Number so i can just go order this thing and stop yanking my hair out LOL
Replies (7)
Message 2 of 8
mcgyvr
Get a decent ($250-450) Nvidia Geforce GTX series card.. (970/980 or so)
You can pick up a 970 for around $340 or so..
Message 3 of 8
Rblaque
Thanks man......i appreciate the feedback, .btw money is no object lol. Ill hear more flack if my machine runs slow than i will for raising the cost of the video card Smiley Wink
Message 4 of 8
mcgyvr
Money is always an object Smiley Very Happy
But you should do just fine with a card like that..
Fast processor "core" speed/ plenty of RAM/quick data access speeds (SSD/fast network) are really critical..
Message 5 of 8
blair
To add to "mcgyvr's" post, go for the fastest "gamming" machine your budget allows. The one problem with Inventor is that within the modeling environment, Inventor can only use a single core of the CPU. So if your work is primarily assembly, go with the fastest clock CPU you can get. If you do FEA and Rendering, then Inventor will use all the cores you can throw at it.
The graphics card is only used within the modelling window to rotate, pan and zoom the model. A really fast Nvida GeForce  900 series and faster card will do.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 6 of 8
Rblaque
Thanks so much...........great info
Message 7 of 8
Rblaque
Heres the build..........Look Good?
Custom Order PC including:
Thermaltake chassis with EVGA 850 Watt power supply,
Asus motherboard, Intel Core i7 CPU at 4.0Ghz,
Crucial 500G SSD, 32G DDR3 memory,
DVDRW, Nvidia GTX980 by Gigabyte, Microsoft Windows 7 Professional 64bit.
$1860
Message 8 of 8
blair
Looks good, I've been using that graphics card for at least a year and really like it.
Delta Tau Chi ΔΤΧ
