Announcements
AISI 4130 Chromoly Tube Steel Library
Does anyone know if there is a Library for thin wall chromoly tube steel that exists?
Mark.Lancaster
Most likely you will have to create your own library for this.  However you may get lucky and someone has already done the work.  But most likely you will be doing it.
If by chance someone does have it you may want to indicate which version of Inventor you are using?  Also is your library desktop or controlled by Vault?
Mark Lancaster
