Invisible link to external iLogic rule
Maxim-CADman77
Advisor Advisor
Message 1 of 18
Maxim-CADman77
A designer reqired the help.
Occasionally Inventor showed an exception message regarding impossibility to find external iLogic rule with particular name (sorry I only have it in Russian and dont know how to get it in English):
Управляемое событиями правило iLogic
RunExternalRule: невозможно найти внешний файл правила с именем:  RusMaterialDescription .
 Additional tab contains info:
System.ArgumentException: RunExternalRule: невозможно найти внешний файл правила с именем:  RusMaterialDescription .
   в iLogic.LowLevelInRule.RunExternalRule(String ruleName, NameValueMap ruleArguments)
   в iLogic.EventsRuleRunner.RunRules(Document doc, iLogicCentral central, InventorEventCode eventCodeA)
Even so it happend in 3Dassembly environment I managed to find the IPT on which issue is reproducible.
It is a Configuration Membe.
Exception occurs on update command (even so Member seems to be saved AFTER Factory).
Please find archive with both files attached.
My questions are:
1. Where exactly in the IPT-file the link is stored
2. How to delete the link from those models completely?
Thanks in advance
Please vote for Inventor-Idea Text Search within Option Names
Replies (17)
Message 2 of 18
Mark.Lancaster
@Maxim-CADman77
Google translate can be used to translate it..  Smiley Wink
Manage events iLogic rule
RunExternalRule: it is impossible to find an external rule file named: RusMaterialDescription.
I haven't looked at your dataset but the message usually means there's an ilogic rule that is trying to launch an external rule that name.  Did you write this code/interface or did someone else?  Also when sharing files you should always indicate your version of Inventor you're using.  At this point we have to download the zip file and then check to see what version you used.
Update:  This dataset is based on Inventor 2014...  But there's nothing in this ipart that you have provided.  There's no iLogic rules at all.  Why do you think its this part file causing the issue?
Mark Lancaster
Message 3 of 18
Curtis_Waguespack
"An System.ArgumentException is thrown: RunExternalRule: cannot find the external file named rules: RusMaterialDescription.
the iLogic. LowLevelInRule. RunExternalRule (String ruleName, NameValueMap ruleArguments)
the iLogic. EventsRuleRunner. RunRules (Document doc, iLogicCentral central, InventorEventCode eventCodeA)"
Hi MaximUdod,
I think this is saying that the external rule named in the error can not be found. Most likely the configuration path is missing or has not been set, or the external rule file is not found at the path that is named in the configuration file.
To check or set the Configuration path close all files and then follow the instruction here:
I hope this helps.
Curtis
Message 4 of 18
Maxim-CADman77
Yes - we are using Inv2014, build 246  (sorry I usually make this note when start new thread)
For me Issue is reproducible on the Configuration Member shared.
This is how it looks just after opening:
Then I press Local Update and get the error:
Error Message
iLogic Event-Driven Rule
RunExternalRule: Cannot find an external rule file named: "RusMaterialDescription".
So IMHO it means some url reside somewhere in CM or CF
BTW: Exact English statement or error is shown when English Inv is run (who might guess ;-))
Message 5 of 18
Maxim-CADman77
The referenced article seems unapplicable for Inv 2014
Message 6 of 18
Maxim-CADman77
I mere guess what was that rule about (it was actual in old Inv2010).
If I put RusMaterialDescription.txt with simplest code (MessageBox.Show("Hello world!", "iLogic Message")) in Configuration Member folder I even see it be executed on Local Update.
My expectation was to make  link visible somewhere (in Event Triggers list?
But my goal is not to reanimate that rule but rather get rid of urls/links to obsolete rules
Any ideas?
Message 7 of 18
Curtis_Waguespack
Smiley Tongue Come on now, you know I can post a 2014 link that says the same thing. This is not a version issue.
Message 8 of 18
Curtis_Waguespack
Hi MaximUdod,
  • It's late here (but I sometimes read up so my mind has time to simmer an issue, so...)
  • We have some 2nd language barriers (and I'm not great with my first language, so...)
  • I've still tying to get a concise statement of the issue:
Can you 'recap' the issue with what you know and don't know?
I think this is completely solvable, but it takes some understanding of what we (you and the rest of us)  don't know.
I think you are asking for some guess of what file is asking for the lost file, but I'm not certain if that is the technical question being asked.
All of that aside, we appreciate your contributions to the Inventor forum, so don't let my clumsy replies (or anyone's)  get in the way.
Also, if it helps please feel free to post on this forum in your natural tongue and we will use Google's translate tools as the go between. Often my second languages come out better with Google rather than through my mind translating. But as I said, my first language is sometimes questionable.
I hope this helps.
Curtis
Message 9 of 18
Maxim-CADman77
Curtis, I'm куфддн sorry for causing misunderstanding
The article you've mention does really applicable to Inv 2014 (I failed to find the "iLogic Configuration" button* on iLogic of Manage tab/iLogic pane** thus made wrong conclusion).
And yes - this piece of knowledge could be used as a fast workaround:
1. Place empty iLogic file to shared folder of fileserver, where we keep working copies of all the rest of iLogic rules
2. Add the folder to iLogic Configuration of each and every PC
Thanks!
But I still hope to find not the workaround but rather solution (how to find the link and erase it forever).
* I think I've never used it before (most likely read and forgotten)
** It was quite tedious day and a bit late time here ... thus my mind probably slowed down extremely (now it is morning time here)
Message 10 of 18
Maxim-CADman77
Curtis,
I still think this is rather technical question (where the link resides* and how to delete it).
BTW, could you reproduce the error on dataset attached to the first post of the thread?
* Which of the two files (CM or CF)?
And where exactly in the file?
As soon as I was the person who was experimenting with that rule (in let say 2011 ... maybe even earlier) I'd expect to find it in Event Triggers (most likely under "Material Change" node) but in CF there is nothing there and in CM Event triggers (as well as the rest buttons of iLogic pane) is grayed out.
Message 11 of 18
Curtis_Waguespack
Curtis,
Hi MaximUdod,
Thanks for the clarification ( it might have just been me who was not understanding Smiley Embarassed). I could not reproduce the issue with the files you attached, and like Mark.Lancaster, I could not find any internal iLogic in those files.
I would think that the Event Triggers are the issue as well, but see nothing there?
I'm not sure what else to suggest. Smiley Frustrated
I hope this helps.
Curtis
Message 12 of 18
MjDeck
Hi Maxim,
The rule-on-event trigger is in the iPart member file in this case. (You could see it, if the Event Triggers command was not disabled when a member file is open in the active window.)
I attached an external rule that will delete all event triggers in the active file. (It would also delete all rules in the file, but there aren't any here.) Open the member file and run the external rule. Then save the member file. That should fix the problem.
I'm guessing that this rule-on-event trigger got into the iPart member from a part template. When a member is generated, it uses the standard IPT template. If the template has triggers and/or rules, those will be copied into the iPart member. If you don't want this, it would be a good idea to create and maintain a non-standard template that you can select (instead of the standard default) when you manually create a part. Put the event triggers and/or rules in this non-standard template. Leave the standard as is, because Inventor will use it when creating iPart members.
Mike Deck
Software Developer
Autodesk, Inc.
Message 13 of 18
ThomasB44
I've reproduced the error you're talking about.
If you suppress the link to iPart factory (then you can cancel this), you can see the rule set by the event trigger.
So I think that at a "X" date, this rule have been set with an event trigger to iPart factory, and propagated to the iPart member.
But if you regenerate the factory member (Rebuild all command & Regenerate command), it will disappear (I mean iPart member will be identical to the iPart factory).
Thomas
Mechanical Designer / Inventor Professional 2025
Inventor Professional EESignature
Message 14 of 18
Maxim-CADman77
Thanks for the note.
But there is something else to consider (not all Members generated at once got the Event Trigger embedded!).
That's pity it's impossible to temporary supress the link to Factory remove the trigger and unsupress link. I see only break command that can't be undone later.
Message 15 of 18
Maxim-CADman77
Mike, thank you a lot
Yourth is almost solution I asked for.
Yes I've extended my desire a bit:
Not only I want to remove the link from the given file (that I've found generally due to intuition*)
but also estimate how many such files are in our Vault.
But strange behaviour of iLogic have failed all my attempts.
One of solutions that failed was to make log files with names of Inv Docs contained EventTriggers to th rule mentioned by using RusMaterialDescription.iLogicVB:
oWrite = System.IO.File.CreateText("D:\_\"&ThisDoc.FileName(True) & ".txt")
oWrite.Close()
It works like a sharm when executed manually but not when Local Update**
I niether get error message*** nor expected txt file.
* Enforced a bit with tracking Inventor calls to folders by ProcessMonitor
** My plan was to run TaskSheduler to update all files in Vault Working Folder.
*** Tthis is expected as soon as rule now in folder from iLogic Configuration
Message 16 of 18
MjDeck
Hi Maxim,
In the file you posted, the rule is tied to the Change Material event. If you don't change the material, the rule won't run. An Update by itself is not enough.
I could send you a rule that would scan all documents in an assembly for rules on events, or specifically on the Change Material event. I could restrict it to just external rules. It would save a list of documents to a file. Would that be useful?
Mike Deck
Software Developer
Autodesk, Inc.
Message 17 of 18
Maxim-CADman77
Mike,
Yes rule that scans assembly (or folder) for rules embedded in Event Triggers would be very helpful for me.
Message 18 of 18
MjDeck
Here's a rule to run in an assembly. It will list all event-driven external rules found in that assembly and its referenced documents. The list goes to a file named ExternalRulesOnEvents_List.txt, in the same folder as the assembly. (It will also work in a part.) Each line in the list file is tab-separated data:
DocumentFileName  EventTypeAndIndex  ExternalRuleName
Mike Deck
Software Developer
Autodesk, Inc.
