Inventor Forum
Invert selection for sketched patterned elements
7 REPLIES 7
Message 1 of 8
timdown73
2448 Views, 7 Replies
Is there a way to invert my selection so that I can subtract or extrude the cicles instead of the area around them?  As is now, I have to select every circle to subtract them from the shape. See image below.  Thanks.
-Tim U.
Intel(R) Core(TM) i7-10875H CPU @ 2.30GHz 2.30 GHz>Memory: 32.0 GB Ram
Op Sys: Windows 10 professional
7 REPLIES 7
Message 2 of 8
mrattray
in reply to: timdown73
No, I don't believe there is a way. However, if you had made this as a feature pattern instead of a sketch pattern, you wouldn't have so many profiles to deal with.
Mike (not Matt) Rattray
Message 3 of 8
timdown73
in reply to: mrattray
Good point.  I'll keep that in mind.  In this case though it's nice to have the sketch dimensions to work with but I suppose if I kept the sketch visible I could still use them.  Thanks mrattray.
-Tim U.
Message 4 of 8
mrattray
If by "to work with" you mean use as parameters, don't forget that pattern spacing and occurences are usable parameters.
Message 5 of 8
JDMather
@Anonymous wrote:
... it's nice to have the sketch dimensions to work with but I suppose if I kept the sketch visible I could still use them.
To emphasize the point already made - you can use those same dimensions you show in your sketch in the Feature Pattern as parameters.
I just had a student do something similar but had other features in the wrong order that would have required starting over.  The solution was to do the feature New Solid and then the Feature Pattern, trim the pattern (which you might not need to do in your case) with the Split command and then finally Combine - Cut.
The multi-body technique saved a lot of rework that would have been involved in starting over.
Message 6 of 8
timdown73
in reply to: JDMather
Thanks for all the help/input guys. I appreciate it.  (Invert selection would still be nice though):smileywink:
-Tim U.
Message 7 of 8
Rory_M
If they're through holes you could keep the selection you have and extrude as "intersect" rather than "cut".
Rory
Message 8 of 8
timdown73
in reply to: Rory_M
Rory_M - You hit the nail on the head.  That's what I needed.  I don't use that option as much as I should.   Thanks man!
-Tim U.
