I have recently downloaded a .stp file of an AOD pump from a manufacturers website. Once I imported it into Inventor the appearance is a rust color and all features have a yellow outline. I am able to insert into a main assembly but I have not found a way to change the color or get rid of the yellow outline. See attached screen print.
Can anyone give me some advise or suggestions?
PE - CTEN
Solved by JDMather. Go to Solution.
Hi estberg,
It looks like your model came in as multiple surfaces, or a composite of surfaces. You might be able to use the Stitch tool to turn them into a solid, or you might need to work a bit harder at it. If you post the file someone can have a look for you.
If keeping the file a surface model is okay, and you are using Inventor 2012 or earlier then you can expand the Surface Bodies node in the browser and then right-click on the Surface node and choose Properties, then you can set the color.
If you're using Inventor 2013 then you'll need to go another route. See this link:
I hope this helps.
Curtis
Yes, I tried to clear the color of the imported model but has no effect.
I am using Inventor Pro 2013
PE - CTEN
Post the url to the download or zip and attach the original file here.
I was able to change the body color using this method but it is still outlined in yellow. Seems like there is a problem with the model I am not seeing. I will continue to work with the model to see if I can repair it. The file is too large to attach.
Anyone know of a resource covering working with imported models?
PE - CTEN
Yes, I tried Curtis's suggestion and I am able to change the color but it is still outlined in yellow.
Here is the URL for the file.
PE - CTEN
It is outlined in yellow because it is a surface body rather than a solid body.
I will take a look and see if it can be solidified.
http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
If you use these Import Options it will import most of the assembly as solid bodies.
The fastenters were still surfaces, but the one I checked looked like it would be easy to solidify (if you know how) first removing some extra surfaces representing the threads.
see attached for the surface bodies
