inventor workflow improvement/hardware question
Message 1 of 9
hello, i use alot of inventor and autocad at my place of work, is there anything out there like the spacemouse enterprise but just the screen with commands? id finish my jobs so much faster if i had a screen like that next to my hand with all the commands.
Replies (8)
Message 2 of 9
swalton
How about a gaming keypad like this: https://www.razer.com/gaming-keyboards-keypads/razer-orbweaver-chroma
You can also memorize the keyboard shortcuts...  See the Tools:Customize command in the Ribbon.
Steve Walton
Inventor 2025
Vault Professional 2025
Message 3 of 9
I_Forge_KC
It's not really intended to do what you want, but it is perfect for the job...
https://www.elgato.com/en/gaming/stream-deck
This is basically a 15 button device that has LCDs in each button - so you can build all kinds of macros and commands. It even has nested options in it so you have the ability to embed UMLIMTED commands into it...
[video]
K. Cornett
Generative Design Consultant / Trainer
Message 4 of 9
Yeah that was my original plan, but I’d have to lean a computer language and write code into autohotkey for it to work
Message 5 of 9
wait i can do hot keys... ordered and shipped 😄
thanks for suggesting it, would of never downloaded the software to see what i can do if you didnt.
Message 6 of 9
gooch12013
With the new ability to have custom shortcuts now. I now use the Elgato Stream Desk.  It works good for my work flow. The only down fall is you must be using windows 10 so the Stream Desk only works on windows 10.
Message 7 of 9
kelly.young
Autodesk Support
Autodesk Support
Great link @I_Forge_KC, thanks for sharing.
@gooch12013 that is pretty cool seeing the Inventor commands on the little buttons, glad to see it worked out for you. Is it contextual, meaning does it change between environments?
@Anonymous did you get yours setup and running as well?
Message 8 of 9
willem.bastiaensGPZB2
By any chance, would you be able to share your icons or profiles used for the elgato streamdeck? I'm beginning to set up my stream deck XL and finding the exact icons seems to be difficult.
Thanks in advence!
KR
Willem
Message 9 of 9
I_Forge_KC
So, gaining access to the icons themselves is a bit tedious, but totally doable.
1. Download "BeCyIconGrabber" - CNET has it
2. Fun the program and swap over to the Search tab
3. Click Browse and navigate to *\Autodesk\Inventor 20XX\Bin
4. Click the Recursively Search Sub Directories option
5. Click OK
6. Now make sure you're on the 32x32 search results and then scroll through until you find what you need
7. Right-Click on the icon and hit save
8. Set options accordingly (e.g. PNG, only 32x32, etc.)
9. Profit
Everything is there. If you're only doing a few dozen, this isn't so hard. If you're nesting the entire command structure into your Streamdeck... don't.
K. Cornett
