I apologize if this is duplicative: I could not find a post that seemed sufficiently on-point.
When I change almost anything about a sub-assembly of an assembly shown in a drawing (DWG), or in a part which is 'of' an assembly shown in a drawing, I often get the yellow lightning bolt, and and the right click menu features 'Update model'. Then, too often, the round robin begins: select the indicated menu option and the offending assembly/LoD is loaded... And then it seems that almost regardless of what sequence of steps I follow thereafter to update the offender and save the new state of the DWG and IAM(s), I face an apparently patternless sequence where, on returning to or re-opening the DWG I am told that the same or a different sub-assembly needs updating. I have tried everything I can think of, including: using the either the small menu button either as 'local update' or 'global update' (and how do these differ, exactly?), rebuild all, rebuild all/update mass, etc.; updating the sub-assembly, saving and closing it, then returning to the DWG and saving it; updating the sub-assembly and saving it, then returning to the DWG and saving and closing it, then closing the sub-assembly and re-opening the DWG; and on and on and over and over.
Then, after a half dozen or a dozen rounds of this, perhaps because I have turned around three times and made a magic sign, it all seems to work, and the dreaded lightning bolts are held at bay. But not conquered, apparently, because not uncommonly everything will be well for a period, and then I will get the dreaded bolt on a sub-assembly were, as far as I can determine, I have changed nothing; but usually this involves a sub-assembly about which Inventor previously complained.
Making changes to iParts is particularly troublesome in causing this sort of not-so-merry-go-round. "Defer updates" is not checked.
So, what is the difference between 'local' update and 'global' update? What is the difference between those two and using 'rebuild all'? And most importantly, what exact sequence should I follow to put a stake through the heart of the lightning bolts, forever and anon, and why?
Inventor Pro 2018, all updates patched in, Win 10-64, etc.
Solved by DavidWHouse. Go to Solution.
So, I have been trying this process, based on the information you provided: When the DWG wants a model (assembly) updated, I use the provided menu option. That loads the assembly in question, with the specific LoD used in the DWG applied and active, then returns me to the DWG as the active window. I select the tab of the assembly/model to be updated, select the 'Master' LoD, and save it to disk.
As such, I have accepted your response as a solution.
