Inventor Forum
INVENTOR, WIRING HARNESS, SPLICE
5 REPLIES 5
430 Views, 5 Replies
IS IT POSSIBLE TO SPLICE WIRES IN OF DIFFERENT GAGES. (I'M USING INVENTOR 9 PRO) I CAN'T SEEM TO CREATE AN ELECTRICAL PIN PIONT ON THE THE ACTUAL WIRE. I CAN ONLY ADD PINS TO PARTS.
ANY HELP?
ANY HELP?
5 REPLIES 5
mmojica, You are correct. We haven't implemented splices in R9. I'm not at liberty to say exactly when they'll get implemented, but they are definately considered in a future release. I think you found the workaround... try adding an electrical pin to a new part and run the wires to it. (I wish I had a better answer for you) -- Hugh Henderson (Inventor Workflow QA) "mmojica" wrote in message news:29568568.1104963497628.JavaMail.jive@jiveforum2.autodesk.com... > IS IT POSSIBLE TO SPLICE WIRES IN OF DIFFERENT GAGES. (I'M USING INVENTOR 9 PRO) I CAN'T SEEM TO CREATE AN ELECTRICAL PIN PIONT ON THE THE ACTUAL WIRE. I CAN ONLY ADD PINS TO PARTS. > ANY HELP?
I am curious. Have you told your competitors that it is acceptable for them to stand inside of your front door, and tell all your customers they would be better off leaving your establishment, and going to theirs? If not, I fail to see where you think you should be able to come in here and do just that. Lets keep the group to tech issues and not who should change cad systems. -- Kent Keller Autodesk Discussion Forum Facilitator "JBrown-Mrc" wrote in message news:32864367.1105039958722.JavaMail.jive@jiveforum1.autodesk.com... > .....BIG brother is watching you.......
Sorry Kent, I was just kidding. I am a die hard Inventor user....
DEATH TO SOLIDWORKS
DEATH TO PRO E
Actually if you try to perform an undo in SWX then you will die trying !!!
And if you try to model simple things in ProWF , you will die of boredom!!
DEATH TO SOLIDWORKS
DEATH TO PRO E
> And if you try to model simple things in ProWF , you will die of boredom!! Aw, come on now. Create a datum sketch, exit, hit the extrude button and type a distance or drag to adjust. How hard can the simple stuff be? (Sorry, Kent. We really should stick to the iv tech stuff and save the disinformation for other places.)
