Inventor using CPU instead of GPU (Inventor 2014)
I have a problem: Everytime I want to render a scene with the visual style "Realistic" my computer is using the CPU for rendering (every Core of the CPU is fully loaded while the GPU-usage is at about 5%). So my question is, is there a possibility to use the GPU instead of the CPU to render a scene?
This problem only occurs when I have the graphics settings set to "Quality" or "Performance". When it's set to "Compatibility" it is using the GPU but I cannot put the visual style to "Realistic". Here are the Graphic-diagnostics:
Quality:
Spoiler
This Direct3D graphics driver is Microsoft WHQL certified
Graphics Hardware Description:
NVIDIA GeForce GTX 970
AIRViz Device Manager \ VirtualDeviceDx11
Feature Level 5_0
Quality Mode
Hardware Renderer
Graphics driver file nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um is version 9.18.13.4788
Current optimization settings are not known
The display is using 32-bit color
Inventor Version:
Build: 246, Release: 2014 SP2 Update 3 - Date: Sun 10/19/2014
64-Bit Edition - 8192.00 GB
Loaded Inventor Add-Ins:
Assembly Bonus Tools
Simulation: Dynamic Simulation
Simulation: Frame Analysis
iCopy
System Information:
Operating System:         64-bit Microsoft Windows 7 Professional  (Build 7601) Service Pack 1
Language:             German
System Manufacturer:         To Be Filled By O.E.M.
System Model:             To Be Filled By O.E.M.
BIOS:                 BIOS Date: 10/31/12 21:41:41 Ver: 04.06.05
Processor:             Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz (1 processor, 4 physical cores, 8 logical cores)
System Memory:             15,888 GB RAM
Graphics Device Information:
Renderer:             HAL
Manufacturer:             NVIDIA
Chip Type:             GeForce GTX 970
DAC Type:             Integrated RAMDAC
Graphics HW Memory:         3,916 GB
Display Mode:             2560 x 1440 (32 bit) (59 Hz)
Graphics driver file:         nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver file version:         9.18.13.4788
Driver Date:             13 March 2015 0:00:00 UTC (Coordinated Universal Time)
Direct3D Graphics Device Information:
Adapter Description:         NVIDIA GeForce GTX 970
Vendor ID string:         0x000010de
Device ID string:         0x000013c2
VendorID:             10de
DeviceID:             13c2
SubSystemID:             367a1458
Revision:             a1
Direct3D 10 / DXGI System Information:
Dedicated Video Memory:     3,916 GB
Dedicated System Memory:     0 MB
Shared System Memory:         7,694 GB
DxDiag System Information:
Operating System:         Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.150202-1526)
Language:             German (Regional Setting: German)
Processor:             Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz (8 CPUs), ~3.5GHz
System Memory:             16384MB RAM
Page File:             5994MB used, 26542MB available
DirectX Version:         DirectX 11
DxDiag Version:         6.01.7601.17514
DxDiag Graphics Device Information:
DirectX Version:         10.0
DDI Version:             11
DDI Version Number:         b
DxDiag WHQL Level:         0
Driver Signed Valid:         True
Driver Signed:             True
Revision:
Graphics HW Memory:         3697 MB
Display Mode:             2560 x 1440 (32 bit) (59Hz)
Driver file version:         9.18.0013.4788
Driver Date:             3/13/2015 21:41:47
WHQL Level:             1
Inventor Options Information:
Options = 0x00000000
Warning Options = 0x00000000
Graphics driver log information:
Mrz/31/2015-22:56:16:    Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Mrz/31/2015-22:57:23:    User changes the graphics driver manually: D3D10 -> D3D11.
Mrz/31/2015-22:58:34:    Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Mrz/31/2015-22:58:44:    User changes the graphics driver manually: D3D10 -> D3D11.
Mrz/31/2015-22:58:51:    Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Mrz/31/2015-22:59:14:    User changes the graphics driver manually: D3D10 -> D3D11.
Mrz/31/2015-23:00:04:    Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Mrz/31/2015-23:36:35:    Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Mrz/31/2015-23:37:04:    User changes the graphics driver manually: D3D10 -> D3D11.
Mrz/31/2015-23:49:44:    Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Mrz/31/2015-23:49:54:    User changes the graphics driver manually: D3D10 -> D3D11.
Apr/01/2015-11:34:28:    Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Apr/01/2015-11:34:46:    User changes the graphics driver manually: D3D10 -> D3D11.
Apr/01/2015-11:36:58:    Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Apr/01/2015-11:37:29:    User changes the graphics driver manually: D3D10 -> D3D11.
Apr/02/2015-00:05:02:    Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Apr/02/2015-00:05:13:    User changes the graphics driver manually: D3D10 -> D3D11.
Apr/02/2015-00:16:08:    Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Apr/02/2015-00:16:29:    User changes the graphics driver manually: D3D10 -> D3D11.
Apr/02/2015-00:18:38:    Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Apr/02/2015-00:21:30:    User changes the graphics driver manually: D3D10 -> D3D11.
Apr/02/2015-00:51:45:    Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Apr/02/2015-00:56:00:    User changes the graphics driver manually: D3D10 -> D3D11.
Apr/02/2015-01:41:56:    Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
Apr/02/2015-01:42:13:    User changes the graphics driver manually: D3D10 -> D3D11.
Compatibility:
Spoiler
Direct3D 10
Hardware Renderer
Graphics driver file nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um is version 9.18.0013.4788
Using Full optimization  (this is the recommended setting)
Inventor Version:
iCopy
System Information:
Operating System:         64-bit Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.150202-1526)
Dedicated System Memory:     0MB
Shared System Memory:         7878MB
Dedicated Video Memory:     4010MB
Page File:             5993MB used, 26543MB available
Renderer:         HAL
DDI Version:         11
Driver Signed:         True
Revision:
VendorID:         10de
DeviceID:         13c2
Revision:         a1
WHQL Level:         1
Inventor Graphics Device Information:
Graphics Hardware Description: NVIDIA GeForce GTX 970
Hardware Library ID: Direct3D 10 \ 0x000010de \ 0x000013c2
Direct3D Hardware ID: 10de \ 13c2 \ 367a1458 \ a1
Inventor Hardware Library Information:
HW Library Version = $Revision: #1 $
HW Library Date = $DateTime: 2013/10/07 16:54:06 $
HW Library OS Name = Windows 7 x64
Inventor Hardware Library Entry Information:
Autodesk Inventor Certification Status:         Gold
Autodesk Inventor Tested Certification Status:         Unknown
Graphics HW Vendor Supported for Autodesk Inventor:     False
Hardware Library 2.0
Settings for optimized and conservative:
Workarounds:  0x00000000, 0x00000000
rating  4, optimization level 2
Texture Font Precision: 256
Display Information:
Back Buffer Format = DXGI_FORMAT_R8G8B8A8_UNORM
Depth Stencil Buffer Format = DXGI_FORMAT_D24_UNORM_S8_UINT
Monochrome Bitmap Format = DXGI_FORMAT_A8_UNORM
Apr/02/2015-14:51:42:    Fail to create D3D11 factory, We need to change it for current inventor session: D3D11 -> D3D10.
I think the problem might be that Inventor is not recognizing DirectX 11 on the GPU and is trying to simulate it with this "VirtualDeviceDx11" on the CPU, but I have no clue how I can change it 😕
I uninstalled the onboard Graphicsdriver, because it used to use the Onboard GPU (although I turned it off in the Bios and in every options I could find). The Graphics Driver of the GTX970 are up to date.
Thanks for every help in advance 🙂
Replies (7)
"Realistic" has an option to turn on or off Ray Tracing.  Check this setting.  If it is on, Ray Tracing currently (and sadly) does not render on the GPU.  I'm hoping in the future they'll support IRay like Max and Maya which does render on the GPU but we don't have it yet.
Thanks for the quick reply 🙂 When I disable Raytracing it seems like Inventor is using the GPU, although it is way overpowered for my small models^^ So I guess it really does not support raytracing on the GPU. Do you maybe know if Inventor 2016 might support it? I have read it is using a different rendering engine.
I'm not sure but I didn't see any mention of it.  This is what we should have: http://www.nvidia.com/object/nvidia-iray.html
Max, Maya and even Revit have it.  Not sure why they didn't go with that as Inventor already has Mental Ray integrated, I thought IRay would be fairly easy to implement.  We'll have to see what 2016 really has when it comes out I guess.
blair
The only time GPU is used in Inventor is for your Model Environment model window (rotate, pan and zoom). Rendering uses your CPU in Inventor. The only software that I know that allows for selection of CPU and GPU is 3dMax.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
@lkrenzler: Yes, that would be pretty awesome if someday Inventor could do it, too^^ But thanks everyone for the help, seems like I have to let the CPU do some work in the next time^^
what about the new nvidia rtx ?, it applies real time ray trcing on videogames
DarrenP
inventor will not use those features
you need to look at 3ds max or maya with arnold to use the new ray tracing fuction
DarrenP
