Inventor to solid works
Message 1 of 12
Hi, I am having some serious issues.
I have a multipart assembly made in the most up to date inventor program. I need to pass it off to someone using solid works to update and make final changes to the model. What file format or process will allow them to do this? Stp. Files seem to not be working it's just crashing on their program. Please help!
Replies (11)
Message 2 of 12
JDMather
STEP should work, but it would probably be better to use Parasolid (*.x_b) as that is the native kernel for SolidWorks.
SolidWorks (of the correct version) can also open Inventor assembly and part files directly.
If you can attach STEP and/or Parasolid here - I can test them out.
Message 3 of 12
ok great! I will try to attach them here.
https://drive.google.com/drive/folders/1XCWcvBOjsoan7SSc8c_ysbT2ejVAI_UK?usp=sharing
PRIVILEGE AND CONFIDENTIALITY NOTICE: The contents of this e-mail
transmission, and any documents, files or previous e-mail messages attached
to it are intended solely for the party or parties addressed and may
contain proprietary or private communication that is legally privileged and
may constitute inside or non-public information under international,
federal or state securities laws. If you are not the intended recipient of
this e-mail message or if this e-mail message has been addressed to you in
error, any review, use, dissemination, distribution, saving or copying of
this e-mail is STRICTLY PROHIBITED. Do not disclose the contents or take
any action in reliance upon the information contained in this e-mail
transmission. Please notify the sender immediately of the error by return
e-mail and/or phone and please delete this message from your system. Please
contact CMS, LLC's corporate office in Baton Rouge, Louisiana, USA at
1.800.256.2803 <(800)%20256-2803> if additional attention is required.
Message 4 of 12
JDMather
Can you explain a bit about how you are doing the export?
I am seeing a lot of what I would consider extraneous details right down to balls and races of bearings and tumblers of locks?
The Parasolid opened fine for me in SolidWorks 2017 (I have 32Gig of RAM), but the STEP has been cranking for a while.  I don't know if it will finish, but I am going to kill the process since the Parasolid worked.
Message 5 of 12
JDMather
It might also be noted that you have made these files available on a public forum.
Did you intend to do that?
Message 6 of 12
All I do to export the parasolid model was just opening up the assembly and
clicking export>3d model format>parasolid
Message 7 of 12
Ya I only kept them posted temporarily, they are gone now. Thankyou
Message 8 of 12
Also, when you opened the parasolid file did it show a trailer or just some bearings and small components?
Message 9 of 12
johnsonshiue
Hi! There are quite a few options. As far as I know, SWX 2018 should be able to import INV 2018 or older releases files directly. Or, you can export INV files as Parasolid or Acis files. Or, you can export INV files as AutoCAD dwg with 3D solids. Or try to convince them to use INV.
Many thanks!
Software Test Engineer
Message 10 of 12
JDMather
This is what I see in SolidWorks.
Took about 1 minute to open.
I can't even find the bearings in the assembly, but are in the folder?
Message 11 of 12
Well at least I know it opens! the picture of the trailer you have posted, is that the parasolid file? And if so, are you able to alter the model, such as dimensions adding or removing parts?
Message 12 of 12
JDMather
@Anonymous wrote:
...And if so, are you able to alter the model, such as dimensions adding or removing parts?
You can see the same thing in Inventor that I can see in SolidWorks by opening the Parasolid file in Inventor.
Yes I can edit parts, add/remove from assembly in SolidWorks, just like in Inventor.
But, it should be noted that direct editing techniques and/or Feature Recognition must be used.
Note that the axle is missing.
I assume this is where the bearings went.
If their job is to do the axle - I think I would look into Shrinkwrap substitute rather then giving them every detail.
