I'm completely new at Inventor and am trying to get a simple sketch done. I used AutoCAD a bit about 15 years ago, so consider me a mostly new user. I have a spline in the YZ axis, I project it 6mm onto another work plane, and I can highlight the bottom node no problem. I wish to create an arc in the XZ axis starting from the base of the spline (which starts at the XZ axis). Up until the point where I choose arc as the sketch, then the snap points/nodes disappear. I would manually just move the arc I create, but it will not snap to the base point of the spline. Am I missing something obvious? I haven't changed anything regarding snap in the settings, as far as I can remember.
The video I'm trying to emulate is here and the arc in question is about 1:08. I followed the guy's steps all the way, but my arc won't behave as his, and it will not attach to the lower node of the spline.
These are my screenshots.
Selectable node at bottom
In sketch mode before selecting arc
Unable to snap to node
Thanks in advance.
