I am having a problem with my project style library. I can't get the part list in the BOM template to shown what I want when I open it. Every article I can find says I just have to change my use library style from read only to read write. As you can see on the attachment, I don't have that option. Is there a command or something to check off to get the read write command on the Use Style Library to function? Any help would be appreciated. Thanks
Solved by Mark.Lancaster. Go to Solution.
@Anonymous
Welcome to the Autodesk User's Community..
You have an old Inventor version which had these options. So READ-WRITE is the same as "YES"
But I don't think you need to do this..
"I can't get the part list in the BOM template to shown what I want when I open it." Can you explain what you mean? Have you set your objects default (style) for your part list to the parts list style that you want?
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous
Did you modify the out of box parts list style or did you create a new one and give it a different name? Also when you start the (new) drawing from your template are you getting a styles conflict message?
Mark Lancaster
@Anonymous
Have you defined your object default to tell Inventor what parts list to use?
Update: You may have another OBJ DEF, I'm just providing the image as a reference.
Mark Lancaster
@Anonymous
Inventor release 10 is way to long ago and I don't remember what it looked like.. Bring up your styles editor and look for obj def.
Mark Lancaster
@Anonymous
When you start a parts list, what does it state for standard..
I know you have an older version of Inventor but you need to look and see.
Mark Lancaster
