Hello every one,
I need to have a viewer or something for view a 3D cad for my ipad
I have inventor 2016
can you help me ?
What is the most easy think to do ?
sorry I speak french ...
You can use your A360 desktop app that was installed with Inventor to upload files to and view them in the Publisher Viewer.
If it's installed on your PC, you can use the A360 folder just like you would with the DropBox, OneDrive or any kind of cloud app and copy your files there.
Please note, you'll have to export your files to the DWF format for Publisher Viewer to open them.
ok and after in the app where I go to find the document ? I put the document in my dropbox in .DWF but i don't know where find them in the app
I believe A360 is viewable on an IPAD
https://itunes.apple.com/us/app/a360-view-share-review-your/id874184071?mt=8
also check out
http://www.autodesk.com/mobile-apps
Yes I download this one but I put the assembly in autodesk 360 and it's load again .. at least 1:30 and its load again ..
in .dwf when I try to open them they say error ... the assembly is to big ?
I have this icon in my taskbar . If I double click that, it opens my A360 drive folder. Do you have this icon in your taskbar?
If not, do you have A360 Desktop listed under Start > All Programs > Autodesk ?
I'm assuming you're running Windows.
I'm sorry, I have misled you. Please look for Autodesk A360 in your app store. Then log into your account.
I apologize, I thought the publisher viewer was the correct app, it was not.
After signing in with A360 App, you should see your drive...
