Hello every one,
I need to have a viewer or something for view a 3D cad for my ipad
I have inventor 2016
can you help me ?
What is the most easy think to do ?
sorry I speak french ...
Hello every one,
can you help me ?
Yes me to but I don't know How to go search my files ... and where I drop it
You can use your A360 desktop app that was installed with Inventor to upload files to and view them in the Publisher Viewer.
If it's installed on your PC, you can use the A360 folder just like you would with the DropBox, OneDrive or any kind of cloud app and copy your files there.
Please note, you'll have to export your files to the DWF format for Publisher Viewer to open them.
ok and after in the app where I go to find the document ? I put the document in my dropbox in .DWF but i don't know where find them in the app
I believe A360 is viewable on an IPAD
https://itunes.apple.com/us/app/a360-view-share-review-your/id874184071?mt=8
also check out
http://www.autodesk.com/mobile-apps
also check out
Yes I download this one but I put the assembly in autodesk 360 and it's load again .. at least 1:30 and its load again ..
in .dwf when I try to open them they say error ... the assembly is to big ?
When you start the Publisher app on the iPad, are there options to press on the bottom of the screen?
yes ? I have MODEL , DOWNLOAD , GALERY
Download is where you will sign into your account and access the DWF files you've uploaded..
and now I have automatic copy and legacy
Did you upload any files to your A360 account? They should be listed on this screen after you log in...
no sorry I don't find my .dwf
I put them at 3 differente place but I can find them
I have this icon in my taskbar . If I double click that, it opens my A360 drive folder. Do you have this icon in your taskbar?
If not, do you have A360 Desktop listed under Start > All Programs > Autodesk ?
I'm assuming you're running Windows.
I don't find them in my ipad .... ( the .DWFX)
I'm sorry, I have misled you. Please look for Autodesk A360 in your app store. Then log into your account.
I apologize, I thought the publisher viewer was the correct app, it was not.
After signing in with A360 App, you should see your drive...
I try to open them in A360 but its write the same thing ... contact the support error ...
