Inventor Forum
Inventor Sweep/Loft question
7 REPLIES 7
Message 1 of 8
michael_wade5DQPP
233 Views, 7 Replies
Hi Guys!  My name is Michael and I and working on this model of a stair case but I am having some trouble.  I have a picture of what I have and what the issue is.  I want a 3D curved wall but with it all at 90 degrees straight up and down.  I also tried doing a loft but that didn't work either, and I messed around with the behaviors for a sweep and nothing else worked.  Does anyone have any ideas on how to fix this issue?Screenshot 2024-05-29 104149.png
7 REPLIES 7
Message 2 of 8
Hi, try drawing the outline and then use 'ruled surface' on the surface panel to get them all in a specific direction.
Then you can thicken it.
James W
Inventor UX Designer
Message 3 of 8
You can't just expect the tool to give the result you want with minimal inputs.
You need to create more references to help the tool understand your goal: guide rails, surfaces, etc.
CCarreiras
Message 4 of 8
Thank you for that!  That really helped.
Message 5 of 8
Thank you so much!  This way worked even better than I hoping for!  It came out exactly like I wanted it to, and before that I didn't think that I would be able to get the flatter area where the two bents meet, and this did it all by itself!  Again, thank you!  Here is what it looks like now!  I will be sure to share the finished product of the stair case with you when I am finished!
Message 6 of 8
Looking at your final product here, why not just do it as an extrusion?
Rusty
Message 7 of 8
An extrusion would have been a lot more complicated because it goes up at an angle and then curves and flattens.  Same thing for the the other bend just inverted.
Message 8 of 8
Well... as an alternative... one minute job using simple tools...
CCarreiras
Technology Administrators
