Inventor Forum
Inventor Suite 2009 on Windows 8.1 0xc0000142 error
6 REPLIES 6
951 Views, 6 Replies
I get this error with Inventor 2009 but Inventor 2015 starts OK.  Any ideas?
6 REPLIES 6
swalton
Inventor 2009 was only supported on Windows 2000, XP and Vista.
See: https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/sfdcarticles/sfdcarticle...
Inventor 2015 was supported on Windows 7, 8, and 8.1.
You may have to find an old XP or Vista machine to continue to run Inventor 2009.
Steve Walton
Inventor 2023
Vault Professional 2023
blair
I thought that 2009 would run on Win 8.1 as long as the latest Service Pack was installed. The only problem is ADSK only goes back to 2010 on their web-site.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
swalton
in reply to: blair
I did find this link to older services packs:
http://jprdintprev-wac.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9242019...
It looks like it is possible to download old service packs.  I went from XP64 to Windows 7 and then to 10, so I don't have any idea if the service packs will help.
Steve Walton
Inventor 2023
ChrisMitchell01
in reply to: swalton
The earliest version of Inventor which was patched to run on win8.1 was 2011. Nothing prior to that will ever work.
-Chris
Chris Mitchell
PDMS Customer Engagment Team
Thanks. Will Inventor 2015 run on Windows10?
mcgyvr
@Anonymous
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Windows-10-support-for-Autodesk-products.html
(a quote from that article)
Further testing of Autodesk 2013–2015 products is required to determine compatibility with Windows 10 and should be considered unsupported on Windows 10 unless explicitly stated otherwise in the details that follow or in the system requirements for that product and version. Please note the following product-specific details:
If you want to move to Windows 10 then you should upgrade to a current version of Inventor..
If you want to stat with Inventor 2015 then you should stay with Windows 8.1
Inventor 2015 is fully supported on Windows 8/8.1 but not Windows 10..
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticles/System-requirements-for-Autodesk-Inventor-2015-products.html
