Today I was working in Inventor Stress Analysis and I've encountered what I assume is a bug. If I right click on a component and hit find in browser it highlights the component but does not scroll to it. After I've done that my context edit contact dialog box pops behind the main window so I can't see it. I've also had major issues generally with dialog boxes popping off screen. I have 5 monitors hooked up and if I change the main monitor ever with Inventor running it will start popping boxes below my screen.. I get them back by "moving" the location of the monitor in the layout settings under windows till I find where that box is located (usually about 3 inches below the middle lower monitor) and drag it back on the main monitor. Has anyone else encountered this issue?
Randy
Inventor 2018.3.1
I've tried the same path that you described and the version of the inventor that I've been using (inventor 2018.2 portuguese br) doens't show the same error (bug).
Hi! The new browser panel does have issues unique to multi-monitor setup. Unfortunately, we don't have a reliable solution for 2018 and 2019.
Many thanks!
