Inventor now freezing and not responding when changing size of content center part or importing content center part.
andrew.stubbsDEEG8
Observer Observer
Message 1 of 11
andrew.stubbsDEEG8
Observer
Observer
Was working fine yesterday, has happened since I've updated to the latest version of Inventor 2023. I am running Windows 10.
Replies (10)
Message 2 of 11
Gabriel_Watson
Message 3 of 11
johnsonshiue
Hi Andrew,
Please try uninstalling 2023.1 update. Does it work better afterwards?
Many thanks!
Software Test Engineer
Message 4 of 11
andrew.stubbsDEEG8
Observer
Observer
Fixed, thank you.
Message 5 of 11
johnsonshiue
Hi Andrew,
Many thanks for your confirmation! There is a known regression in 2023.1 in case you are not aware. If you have "Prehighlighting" turned off (Tools -> App Options -> Colors), the object selection in the graphics window will be blocked. To avoid the issue, you may turn on "Prehighlighting" or unload "Fusion Interop Add-In" (if you don't collaborate with Fusion). In the meantime, we are working on a fix to correct the behavior asap.
Thanks again!
Message 6 of 11
richard.kFK4QA
Deleted.
Message 7 of 11
richard.kFK4QA
Any progress on this? Inventor Professional 2021.4 sometimes freezes for two minutes after placing Content Centre part. Have to restart Inventor to stop it happening.
Message 8 of 11
NielsDWPT
I have the 2023.2.1 Update  and I still run into this problem. I place  a content center part after which I hit the right mouse key and select OK. after I selected OK, the system freezes for about 30 seconds after which everything runs fine again... until I use the content center again. How can this be fixed?
Message 9 of 11
johnsonshiue
Hi! I believe your issue is different than the OP's. Yours is related to display settings. Close Inventor and go to Windows Display settings and select the recommended resolution and scale. Right-click on Inventor desktop icon -> Properties -> Compatibility -> Change High DPI settings -> check both boxes.
Does it work better now?
Many thanks!
Message 10 of 11
richard.kFK4QA
OK, I have made that change. Will let you know what happens
Richard
Message 11 of 11
NielsDWPT
Thanks @johnsonshiue , This works perfectly!
