Inventor Nesting - Upload materials database
MariaManuela
Advisor Advisor
MariaManuela
Hi All,
Is it possible to upload a file with the materials used into Nesting Process Material Library?
For example an excel file with the sheet metal thickness information?
Thanks in advance
hongjie.cheng
No, currently you can not upload files contain materials into material library.
A workaround is that, you can define all your materials in a .inest document(without sources), then you save that .inest document as a template, next time, when you new a nest document, you can select that saved template file, then you can reuse the materials within that document.
thanks,
Rick
