Inventor Forum
Inventor Nesting - problem with material thickness
0 REPLIES 0
Message 1 of 1
michal_drewniak
54 Views, 0 Replies
Namaste,
I created a project.
I made two elements, the base and the rib, which I later copied in the model.
Two problems occurred during nesting:
1. One of the elements (żebro_036) does not load due to an error.
2. Two elements (made in the sketch - podstawa and żebro_001) do not have the appropriate thickness, Nesting sees them as 0.5mm and not 5mm. I tried to use the solution from this forum, but it doesn't work. I also can't add or change the thickness after loading the files into Inventor Nesting.
Inventor Professional 2025 build 162, release 2025.0.1, date 05/13/2025
Inventor Nesting 2025, ver. 9.0.38
0 REPLIES 0
Technology Administrators
