Positional Reps won't propagate in circular pattern.
I work with designing tools for pipelines.  Being that they're round, I use a lot of radial circular patterning.  I find it very frustrating that positional representations made to the first instance of the pattern do not always propagate through all the other instances.  I have figured out a work around where I activate the pos-rep I want and then expand the pattern in the tree and manually override each instance.  However, when you have 96 instances in the pattern, it takes forever to click each on individually.  Which brings me to my next gripe; why can't I ctrl-click on multiple instances and collectively override them all?  As soon as I select more than one sub-assembly, the option to change pos-rep becomes greyed out.
Any ideas as to how I can fix this?
johnsonshiue
Hi John,
I believe that is the way it works unfortunately. I don't think Component Pattern is aware of the PosRep. Each occurrence may need to be overridden PosRep individually. It is possible there is a bug in this case. Please share the example here or send it to me directly (johnson.shiue@autodesk.com). I would like to understand it better.
Many thanks!
Software Test Engineer
softwaremanagement
Having the excact same problem here. Indeed, it's needed to change the positional representation for each and every instance of a pattern. Working on a parametric assembly here... This kind of destroys the whole purpose of having an automated assembly. Any solutions or workarounds?
johnsonshiue
Hi! Besides manually activate the PosRep, you can use iLogic rule to automate the process.
Many thanks!
SER4
Please vote for this:
Pattern to include Positional Representation - Autodesk Community
P.Eng. Mechanical Engineer
Dell Precision 5680 Laptop; Win11 Pro; 64GB RAM; i9-13900H CPU; Intel Iris Xe Graphics, NVIDIA RTX 3500 Ada Laptop GPU.
Vault Pro 2025.1 (30.1.63.0); Inventor Pro 2025.1.1 (241).
